Help broke my pcie connector on the mother board.
Sad
I broke the hinge of the pcie nvme connector on the motherboard!
Now i'm seaching for a replacement part.
On the wiki the connector is referenced as U7001 and in the schematics as U7001 / BL102-G35-1FR
Is there someone on the forum who can tell me the (digi-key) partnumber is? Any partnumber of a suplier is ok.
Sorry for my crappy english not my native language
Grtz, Ron
Hi Ron,
I'll try and track down what component this is tomorrow. I couldn't find anything on this part number online, so I will take a look tomorrow with my microscope.
In the meantime, tape should hold it down pretty well. Blu-tack might also work well.
I'll let you know if/when I find the part.
I couldn't find anything online either. Which is another reason why we need a BOM.
(02-02-2020, 01:23 PM)zaius Wrote: I couldn't find anything online either.  Which is another reason why we need a BOM.
Yes,
And should by easy auto generated with the schematic / pcb design software :-)
(02-02-2020, 01:37 PM)roncromberge Wrote: And should by easy auto generated with the schematic / pcb design software :-)
True, but even if that weren't the case, Pine would still need one to order parts.
Let's hope they get/got one!
I do feel that it would be in the spirit of the PBP to release the BOM, so people can do self-repairs more easily.
(02-01-2020, 01:14 PM)roncromberge Wrote: Hello,
Grtz, Ron
https://www.digikey.com/en/resources/con...connectors
I haven't yet gotten to it. If I can't find the part number I'll try to measure the connector on all sides with a calliper so we can find a compatible connector.
(02-03-2020, 07:45 PM)Natrox Wrote: I haven't yet gotten to it. If I can't find the part number I'll try to measure the connector on all sides with a calliper so we can find a compatible connector.
So, no part number on the board, but I did get all the dimensions.
[Image: hv3a9tm.png]
I searched on Digi-Key, but could not find a bottom-pin connector that was compatible. There was only a top-pin connector that seemed viable, and though I suppose you could bend the ribbon cable inwards to make it work like that, it's not a better solution to your problem. I've also checked Mouser and Farnell - nothing.
If you wish to look yourself, check for 35 pin 0.25mm FPC connectors with contacts on bottom. If you manage to find one, lemme know!
I wish you the best of luck.
  pbp replacement board altacus 0 2,110 01-10-2022, 11:27 AM
Last Post: altacus
  Did I kill my PBP's board? overlisted 7 13,133 11-12-2020, 03:28 PM
Last Post: overlisted
  Pinebook Pro PCIe init issue R32Fanboy 4 9,261 11-05-2020, 09:59 AM
Last Post: vssz
  PCIe 12v power issue dlan17 1 3,834 05-12-2020, 05:25 AM
Last Post: Arwen
  PineBook Pro Stemma QT connector for Hardware Hacking ssfrfr@ 2 5,780 03-30-2020, 10:35 AM
Last Post: xmixahlx
  Last update broke netflix fpex73 2 6,110 02-25-2020, 06:32 AM
Last Post: fpex73
