Can't access login
Inadvertently I chose a photo in some start up menu. Now on start up the photo fills the screen and I can't log in. Anyway to get around this?
I'm not sure where you would delete the photo from command line so maybe someone here can chime in but when it's booted you can press ctrl+alt+F1 to get into the terminal and navigate to that location to remove. Then either type logout or press ctrl+alt+f7 to get back. Hope this gets you in the right direction. Good luck
Thanks; it got me in. I should be able to manage from here.
(01-28-2020, 09:48 PM)evj Wrote: Thanks; it got me in. I should be able to manage from here.
Glad it helped. Did you get it sorted out?
  First access denied IMSAI8080 3 6,564 06-07-2021, 01:08 PM
  Graphical login hanging after password entry mhill8 2 6,566 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  PBP Went Blank After Login iscmob 2 7,268 12-07-2020, 09:28 AM
Last Post: iscmob
  Private Internet Access VPN on Pinebook Pro 11Eleven 13 25,418 10-27-2020, 05:35 PM
Last Post: AronShap
  Pinebook Pro Won't Accept Login GFreeman 16 30,311 09-03-2020, 11:44 AM
  Login screen issue. LinuXchoicE 2 7,350 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Stuck on login screen Kscott6969 0 3,480 04-20-2020, 10:58 PM
Last Post: Kscott6969
  default os: loop while login as rock gritibaenz 8 15,519 03-10-2020, 03:14 PM
Last Post: gritibaenz
  The usage/access of the SPI flash aaspectre 2 6,177 01-06-2020, 08:14 AM
Last Post: aaspectre
  Wrong keyboard Lay-out in Login and terminal Firedevil79 1 5,521 12-04-2019, 08:50 AM
Last Post: ndp
