Article: OpenOCD on Raspberry Pi: Better with SWD on SPI
Hi PineTime Fans: I have modified OpenOCD to run on Raspberry Pi using the faster SPI interface (31 MHz!) instead of the old GPIO Bit Banging.  If this works, we should be able to flash AND debug PineTime firmware with VSCode on Raspberry Pi!
But I need your help to test this modified version of OpenOCD.  (Test instructions are in the article below)  If it's tested OK, I'll publish the steps to debug PineTime firmware on VSCode.  Please lemme know if it works. Thanks! :-)
Wow, that's a lot of information Big Grin . Thanks.
Do you think this might work with a Raspberry Pi Zero as well ?
No harm trying [emoji3]
Happy to confirm that it works just fine with the RPi Zero.
Awesome... Thanks so much! [emoji3]
(01-18-2020, 01:23 AM)lupyuen Wrote: Hi PineTime Fans: I have modified OpenOCD to run on Raspberry Pi using the faster SPI interface (31 MHz!) instead of the old GPIO Bit Banging.  If this works, we should be able to flash AND debug PineTime firmware with VSCode on Raspberry Pi!
I'm trying to follow this and so far not having any luck. But this is also my first time doing this sort of thing (SPI, SWD) at all, so I'm probably doing something very obviously wrong.
I successfully built OpenOCD following your instructions. When I connect the pins (using the cable that came with the PineTime) and run flash-unprotect on the Pi, I get:
+ openocd/bin/openocd -f scripts/nrf52-pi/swd-pi.ocd -f scripts/nrf52-pi/flash-unprotect.ocd
Open On-Chip Debugger 0.10.0+dev-01130-g9d1b46f5 (2020-04-02-21:55)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'swd'
force hard breakpoints
Info : BCM2835 SPI SWD driver
Info : SWD only mode enabled
Info : clock speed 31200 kHz
and it just returns instantly after that; no error.
Sometimes there is one more line:
Info : SWD DPIDR 0x0193b434
but not often.
Any ideas? Are there logs I can enable / look at?
Thanks so much for doing the work on this!
-john
  Article: My First Week As Embedded FOSS Advocate lupyuen 3 9,988 03-26-2020, 07:10 PM
Last Post: aalevy
  Article: Visual Rust for PineTime Smart Watch lupyuen 1 7,769 03-09-2020, 05:47 PM
  Article: CHIP-8 Game Emulator in Rust for PineTime Smart Watch lupyuen 0 4,841 03-04-2020, 08:13 PM
Last Post: lupyuen
  Article: Debug RIOT-OS on PineTime with VSCode lupyuen 0 4,639 02-02-2020, 01:43 AM
Last Post: lupyuen
  Article: Debug Rust+Mynewt Firmware for PineTime on Raspberry Pi lupyuen 4 10,744 01-24-2020, 05:20 AM
Last Post: lupyuen
  Article: Build and Flash Rust+Mynewt Firmware for PineTime Smart Watch lupyuen 8 18,180 01-18-2020, 01:01 AM
Last Post: clover
  Article: Optimising PineTime’s Display Driver with Rust and Mynewt lupyuen 0 4,516 12-28-2019, 05:46 PM
Last Post: lupyuen
  Article: Porting [druid] Rust Widgets to PineTime Smart Watch lupyuen 3 9,771 12-19-2019, 04:31 AM
Last Post: lupyuen
  Article: Building a Rust Driver for PineTime’s Touch Controller lupyuen 1 6,424 11-22-2019, 08:46 AM
Last Post: xalius
  Article: Sneak Peek of PineTime Smart Watch… And why it’s perfect for teaching IoT lupyuen 0 5,073 11-15-2019, 02:18 AM
Last Post: lupyuen
