Similar Smart Watch
There is a Kickstarter project for a "hackable Smart Watch" that uses very similar hardware as the PineTime called the Bangle.js
https://www.kickstarter.com/projects/gfw...mart-watch
(11-11-2019, 04:59 PM)VMMainFrame Wrote: There is a Kickstarter project for a "hackable Smart Watch" that uses very similar hardware as the PineTime called the Bangle.js
So the kickstarter project is finished. Site to pre order is https://www.espruino.com/Bangle.js.
This watch is interesting because it has open software, with a pitch of easy writing of applications. Moreover, the hardware is identical?!
Same processor, same ram same resolution.
Don"t know about the sensors, or if pinetime has gps.
So could it be as easy as just flashing bangle.js and we've got an ecosystem on the pinetime?
It's certainly interesting, and might be portable, but there are some differences we'd certainly need to deal with before it will be usable.
The PineTime doesn't have the GPS so that's out.
The bangle has 3 hardware buttons plus 2 soft buttons. The hardware buttons are integral to the UI operation, so we'd need to reimplement to use soft buttons. They're also used in the reset process - not sure what we'd do about that.
Sensors/screen - not sure if they're compatible, so might need a different set of drivers.
Bangle.js technical details
Screen controller: same controller but different mode (parallel for Bangle.js, SPI for PineTime)
Touch controller: different - plus the 'touch left/right' have hardware pins so aren't really 'soft' buttons
Accelerometer: different
HRM: different
Magnetometer: only on Bangle.js
Flash: possibly similar
So a port may be possible but isn't going to be trivial, and unless they're on board with the reduced feature set device the app compatibility may be a pain. It seems worth investigating though.
This one here also seems interesting:
https://www.cnx-software.com/2019/12/31/...co-d4-sip/
It has a development board as an extension which prevents the whole malarkey to connect to the PineTime.
  Custom Watch Faces Performance sophiasmith 0 1,341 01-03-2026, 02:23 AM
Last Post: sophiasmith
  Making watch vibrate using Python from a Raspberry Pi YoungRechnitz 0 1,627 03-27-2025, 03:51 PM
Last Post: YoungRechnitz
  Another stuck watch! Ralpharama 11 11,912 06-07-2023, 09:10 AM
Last Post: Ralpharama
  Update of new watch consistently fails bitreaper 5 9,185 06-01-2023, 02:29 AM
Last Post: feketej
  Whoops! Developing games on this (apparently not Linux) watch. Www 2 4,690 06-26-2022, 07:12 AM
Last Post: Www
Question Open box, upgrade, dead watch? ahaplesshappenstance 5 7,256 06-25-2022, 03:13 PM
Last Post: ahaplesshappenstance
Question What can/can't I do with a PineTime smart watch (sealed)? danimations 7 13,064 04-16-2022, 07:18 AM
Last Post: _slowmanship_
  Another similar smart watch VMMainFrame 3 9,201 09-16-2020, 02:33 AM
Last Post: danielo515
  How do I easily charge the watch? Paranoid 18 32,772 06-17-2020, 10:12 AM
Last Post: VMMainFrame
