Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)]
#21
(04-08-2016, 01:56 PM)Tarjei85 Wrote:
(04-07-2016, 03:06 PM)CaptainZalo Wrote: Just got my board today. I'm eagerly looking forward to getting my filthy hands on that STL-file, and I was thinking about running it through a lasercutter and make the whole thing in laquered wood. Wink
And its done... Here is the stl file. No guaranties that it is without error. I dont have the tools to check it. This is one file for the whole thing (exploded so none of the sides is in contact with each other.
If it is preferable I can generate individual STL files for each side...
Here is the file!
*Keep in mind that the scaling of this model is in mm
Sweet. I sent you a mail. If you're interrested, pop me one back.
And than I have updated the STL file to allso contain spacer for the Pine board. The spacers are 4mm in height so you end up wit a 1mm clearance in the area of the mounting brackets for the sidepanels.
Just use the link I posted earlier (I did overwrite the old file)
I get "Item might not exist or is no longer available" message. Would you mind checking the share settings and link in your original post, mate?
Will do. I got my pine yesterday and found out I will need to raise the cutouts to get more free space underneath the pine (for the soldering points) so I will come back here when its done and the file is reposted Wink
(04-12-2016, 03:47 AM)Tarjei85 Wrote: Will do. I got my pine yesterday and found out I will need to raise the cutouts to get more free space underneath the pine (for the soldering points) so I will come back here when its done and the file is reposted Wink
Grats! W00t!
Looking forward to pictures of the case once we get them printed/etched.
Any news on the finished STL-file? I got a mate ready with plywood and a lasercutter. ;-)
(04-12-2016, 02:29 AM)CaptainZalo Wrote: I get "Item might not exist or is no longer available" message. Would you mind checking the share settings and link in your original post, mate?
I stumbled across this conversation. And I'm so glad I did. This case looks awesome, I am still waiting for my Pine to arrive but my 3d printer would love to give this print a bash.
I'm using my Pine as an IoT hub so that cube would look so cool.... pending what the fiancé says  Tongue. In any case, thanks for sharing and also looking forward to the STL
I will try to finish the model tonight and post the STL late tonight/tomorrow morning.
Thank you DarkstarSA for the kind words. The only request I have for people using my STL is that you all post pictures of it when it is finnished Wink
(04-26-2016, 04:53 AM)Tarjei85 Wrote: I will try to finish the model tonight and post the STL late tonight/tomorrow morning.
No stress on getting it done, I know its your own time doing this and I do appreciate it.
I'll most definitely post pictures when it is done  Smile
And finally the new, updated STL file is ready (only took me an hour, but its 00:30 here now, and its up again for work at 04:30, so now its good night to you all.
The new updates is raising the cutouts with 5mm so there is room for the soldering points and pins underneath the Pine.
I have also raised the spacers with 5mm to match the cutouts.
BE AWARE!!! I have not checked the STL (running Windows 8.1 on this machine  Dodgy ) so If anyone want to check the STL and if necessary fix it (I know the built in STL software in Windows 10 can do this) and then PM me the file I will update the GDrive file right away.
Sorry for all the delay on this update. It has been a crazy couple of weeks lately.
And last.... HERE is the STL file  Big Grin
Photo Weatherproof case build ltorsini 12 41,104 07-07-2026, 07:01 PM
Last Post: ltorsini
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,190 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 20,110 02-22-2019, 03:24 AM
Last Post: GaryFunk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,600 10-12-2018, 03:08 PM
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,686 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,152 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 16,478 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 141,739 03-30-2017, 11:36 AM
Last Post: Luke
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 38,993 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 22,269 10-24-2016, 08:18 AM
Last Post: killor
