Upgrade Debian kernel on a SD/SATA drive boot combo.
I currently have:
Linux taz 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 GNU/Linux
Debian 9
Root is on sda2
Boot is on the sd card (/dev/mmcblk0p*)
I am trying to upgrade it to a later release so I can get fan control (I have no pwm device). I've used aptitude to jump to 5.4.0-rc1-1120 but I don't seem to get it to reboot to it. I see a number of files on /boot (on the SD card) and I'm not sure if I need to change any of them (the efi is not something I've figured out yet).
So you have a new kernel installed but it doesn't boot? Do you have any logs via serial console or on screen?
(12-03-2019, 05:15 PM)xalius Wrote: So you have a new kernel installed but it doesn't boot? Do you have any logs via serial console or on screen?
Not yet, I need to hook up the USB dongle to it again. The syslog and the dmesg don't say anything.
Finally got the console setup (and boy does that prompt go by fast, need to fix that later). Here's what I'm seeing:
Scanning mmc 1:7... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 2059 bytes read in 23 ms (86.9 KiB/s) select kernel 1:      kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524 2:      org-kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524 3:      org-kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524 4:      kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524-memtest Enter choice:
Okay I see a problem, there's no 5.5 in the list. I've update an extlinux.conf. But there are 2, one under /boot/efi/extlinux and the other under /boot/extlinux. So my guess if neither is correct and that the new funky efi stuff needs to have more done before it can see the 5.5 Kernel.
Any pointer?
You need to get the new kernel back on the SDcard to boot it. Something like
sudo mount /dev/mmcblk0p7 /mnt/ sudo rsync -ax --delete /boot/ /mnt/boot/
ps - good luck with 5.4 - be ready to manually edit your SDcard to revert to 4.4 if your luck is anything like mine, see this thread.
(12-11-2019, 01:23 PM)dukla2000 Wrote: You need to get the new kernel back on the SDcard to boot it. Something like
What could possibly go wrong ... ;-)
I'll set up a second SD and try that out.
(12-11-2019, 11:40 PM)linuxha Wrote: I'll set up a second SD and try that out.
You don't need a second SDcard: if it fails then you just need another PC you can edit the /boot/extlinux/extlinux.conf file on. Either add a efaultt line or make sure the 4.4 section is the first one.
e.g. with the file below I boot 4.4.197
$ cat /boot/extlinux/extlinux.conf timeout 10 menu title select kernel default kernel-4.4.197 label kernel-4.4.202    kernel /boot/vmlinuz-4.4.202-1237-rockchip-ayufan-gfd4492386213    initrd /boot/initrd.img-4.4.202-1237-rockchip-ayufan-gfd4492386213    devicetreedir /boot/dtbs/4.4.202-1237-rockchip-ayufan-gfd4492386213    append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4 label kernel-4.4.197    kernel /boot/vmlinuz-4.4.197-1236-rockchip-ayufan-g30faab37e339    initrd /boot/initrd.img-4.4.197-1236-rockchip-ayufan-g30faab37e339    devicetreedir /boot/dtbs/4.4.197-1236-rockchip-ayufan-g30faab37e339    append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
  Freezes and kernel panics with Debian trixie jssfr 4 4,241 04-15-2026, 06:48 PM
Last Post: prahal
  Boot/Shutdown on timer captainmorgan 8 16,378 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,244 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,714 08-16-2023, 01:34 AM
Last Post: varac
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 7,063 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 3,092 04-23-2023, 11:02 PM
Last Post: Thisone
Question nand-sata-install on RAID-1 array ARMandHammer 1 3,782 02-12-2023, 03:10 AM
Last Post: igorp
  RockPro64 boot questions misterc 3 6,900 01-13-2023, 06:21 PM
Last Post: misterc
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,177 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  hello i want to drive an edp screen with my rockpro64 hannescam 0 2,296 10-20-2022, 01:22 PM
Last Post: hannescam
