Wrong resolution on external monitor
When I connect a monitor via hdmi port (which resides on a USB-C hub), the Pinebook Pro decides to choose a wrong resolution. dmesg shows, that the monitors resolution of 1680x1050  is announced, but the set to a lower resolution of 1024x768. What can I do to keep the monitors resolution? I append the dmesg's output:
[ 1964.973219] wl_run_escan: LEGACY_SCAN sync ID: 25, bssidx: 0 [ 2084.964338] wl_run_escan: LEGACY_SCAN sync ID: 26, bssidx: 0 [ 2204.970521] wl_run_escan: LEGACY_SCAN sync ID: 27, bssidx: 0 [ 2324.974063] wl_run_escan: LEGACY_SCAN sync ID: 28, bssidx: 0 [ 2444.977071] wl_run_escan: LEGACY_SCAN sync ID: 29, bssidx: 0 [ 2454.324170] fusb302 4-0022: attention, dp_status 9a [ 2454.324587] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn [ 2454.725233] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1680x1050p0, type: 10 [ 2454.730653] cdn-dp fec00000.dp: 2700Mbps x 2lanes [ 2517.578690] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply from device tree [ 2517.578721] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply property in node /power-management@ff310000/power-controller failed [ 2517.613120] fusb302 4-0022: attention, dp_status 19a [ 2517.613518] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn [ 2517.640606] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply from device tree [ 2517.640636] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply property in node /power-management@ff310000/power-controller failed [ 2517.714332] fusb302 4-0022: attention, dp_status 19a [ 2517.839090] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link [ 2517.842296] cdn-dp fec00000.dp: 2700Mbps x 2lanes [ 2517.876548] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p0, type: 10 [ 2517.918330] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p0, type: 14 [ 2517.944504] rockchip-dp ff970000.edp: [drm:analogix_dp_link_start] Enable downspread on the sink [ 2517.949571] rockchip-dp ff970000.edp: Link Training Clock Recovery success [ 2517.952185] rockchip-dp ff970000.edp: Link Training success! [ 2531.066030] fusb302 4-0022: attention, dp_status 19a [ 2531.066231] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn [ 2531.094537] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 14 [ 2531.133833] rockchip-dp ff970000.edp: [drm:analogix_dp_link_start] Enable downspread on the sink [ 2531.136888] rockchip-dp ff970000.edp: Link Training Clock Recovery success [ 2531.138341] rockchip-dp ff970000.edp: Link Training success! [ 2531.166542] fusb302 4-0022: attention, dp_status 19a [ 2531.287242] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link [ 2531.290530] cdn-dp fec00000.dp: 1620Mbps x 2lanes [ 2531.337748] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p60, type: 10 [ 2555.807734] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p0, type: 14 [ 2555.850406] rockchip-dp ff970000.edp: [drm:analogix_dp_link_start] Enable downspread on the sink [ 2555.854127] rockchip-dp ff970000.edp: Link Training Clock Recovery success [ 2555.856205] rockchip-dp ff970000.edp: Link Training success! [ 2564.976728] wl_run_escan: LEGACY_SCAN sync ID: 30, bssidx: 0 [ 2633.016519] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p0, type: 14 [ 2633.056441] rockchip-dp ff970000.edp: [drm:analogix_dp_link_start] Enable downspread on the sink [ 2633.060114] rockchip-dp ff970000.edp: Link Training Clock Recovery success [ 2633.061728] rockchip-dp ff970000.edp: Link Training success! [ 2664.782286] fusb302 4-0022: attention, dp_status 19a [ 2664.782612] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected, not enabled. Enabling cdn [ 2664.858662] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p0, type: 14 [ 2664.882869] fusb302 4-0022: attention, dp_status 19a [ 2664.883537] rockchip-dp ff970000.edp: [drm:analogix_dp_link_start] Enable downspread on the sink [ 2664.887178] rockchip-dp ff970000.edp: Link Training Clock Recovery success [ 2664.888755] rockchip-dp ff970000.edp: Link Training success! [ 2665.005392] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Connected with sink. Re-train link [ 2665.008731] cdn-dp fec00000.dp: 1620Mbps x 2lanes [ 2665.076362] rockchip-vop ff8f0000.vop: [drm:vop_crtc_enable] Update mode to 1024x768p0, type: 10 [ 2684.979849] wl_run_escan: LEGACY_SCAN sync ID: 31, bssidx: 0 [ 2691.393900] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p0, type: 14 [ 2691.435076] rockchip-dp ff970000.edp: [drm:analogix_dp_link_start] Enable downspread on the sink [ 2691.439657] rockchip-dp ff970000.edp: Link Training Clock Recovery success [ 2691.442173] rockchip-dp ff970000.edp: Link Training success! [ 2804.979824] wl_run_escan: LEGACY_SCAN sync ID: 32, bssidx: 0 [ 2907.896835] fusb302 4-0022: attention, dp_status 1a [ 2907.897251] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 2924.980531] wl_run_escan: LEGACY_SCAN sync ID: 33, bssidx: 0 [ 2969.465450] r8152 8-1.2:1.0 eth0: Stop submitting intr, status -71 [ 2969.467386] fusb302 4-0022: connection has disconnected
Same problem.
Pinebook Pro, standard config (Manjaro)
Hi, I solved the problem by going to the screen options, the physical screen options, with the remote control.
For my screen model: "settings" button on the remote control,
image -> image format -> adjust on screen -> activated
I hope it will help you. Wink
  Pinebook Pro Dock - cannot connect to monitor Dominik 4 7,907 06-12-2022, 10:53 AM
Last Post: Rosbeefandino
Question External Monitor not Working sciolus 5 11,073 05-05-2021, 02:05 AM
Last Post: aurora.borealis
Shocked Is there a RIght and Wrong MicroSD? SpaceLord 4 9,657 03-15-2021, 09:17 PM
Last Post: dsimic
  Auto-wake behavior when external power is connected diodelass 7 16,826 12-05-2020, 01:19 AM
Last Post: dsimic
  What are the actual supported framerate/resolution pairs for the PBP webcam? gleachkr 2 6,469 09-19-2020, 10:23 AM
Last Post: xmixahlx
  PBP Battery issues. Drainage on load with external accessories WhiteDragon 11 24,961 09-02-2020, 05:42 AM
Last Post: Nora No
  USB3 won't power 2,5" external HDD Tiedemate 8 18,941 01-08-2020, 05:45 PM
Last Post: Tiedemate
  You toggled wrong switch - Pinebook Pro will not power on hmuller 0 4,029 11-07-2019, 01:25 PM
Last Post: hmuller
