Android Images (ROCK64)
#61
(06-20-2019, 12:13 AM)pineadmin Wrote: Added Stock Build Android 9.0 [eMMC Boot] [20190617] to Wiki and Pine64 Installer
Tried all available Android 9.0 ( I got eMMC flash using android tool and micro SD)
The only one that can boot up for me is 64gb (on micro SD) android 9.0 image and it doesn't have wifi support.... (onboard lan working only)
>>http://files.pine64.org/os/ROCK64/android/ROCK64_dd_20190621_stock_rooted_android_9.0_sdboot-64GB.img.gz
My wifi adapter is
>>https://store.pine64.org/?product=rock64-usb-3-0-dual-band-1200mbps-wifi-802-11abgnac-rtl8812au-adapter
Will anyone able to build that android again with rtl8812au support ?
appreciated.
I've successfully installed and booted via SD in android 9. Where is the app store? The goal is to install HULU etc..
My wifi adapter is
appreciated.
I wonder if that's enough to enable the driver in the appropriate Linux kernel inside the Android 9 source repository?
anyone know any good android image, so everything is working with it? Android 7.1.2 - youtube does not work and many apps giving errors and reboot, android 8 does not even boot, android 9 does not have wifi dongles support...
Does anyone know android image, which works OK with this board? NOT A ANDROID TV ONE, TABLET ONE!
@tllim and @pineadmin would it be possible to include Google Play Store by default on Android TV 9.0 images, please? I see that Google Play Store is preinstalled on Android TV 8.x images.
(04-11-2020, 04:30 PM)Pepe Wrote: @tllim and @pineadmin would it be possible to include Google Play Store by default on Android TV 9.0 images, please? I see that Google Play Store is preinstalled on Android TV 8.x images.
as we understanding, google tighten the Google Play Store installation on Android 9 unless pass their GMS certification. Due to this reason, no longer includes Google Play Store on all new release.
Too bad. I think it might worth getting the GMS certification at least for Pine Phone. If there is no Google Play Store on all new releases will you provide at least some community post to install it?
(04-19-2020, 06:30 AM)Pepe Wrote: Too bad. I think it might worth getting the GMS certification at least for Pine Phone. If there is no Google Play Store on all new releases will you provide at least some community post to install it?
There is no plan to have stock Android OS for PinePhone.
When will a new firmware version of Android 9 or 10 be released for this board?
Can the source code be merged with the latest BSP/SDK from ROCKCHIP ? Would love to have a more efficient android os then what is available from the Wiki software downloads.
Thank you
Hi Pine64 support,
i have purchased the ROCK64 ver3 board and wanted to try the ANDRIOD on it. I tried all andriod imaged and found none of them boots (no display, no LED activity too). it works with all the linux images under ver 3 and ver 2 wiki page.
Can anyone help me? i have tried using the dd mode and SD flasher from wiki page. sandisk SDcards tired are,
1.  64GB A1 class 10 microsd xc 1
2. 8GB class 10 microsd hc 1
Any help is highly appriciated.
  rock64-android10-tv patchset for Firely AlexS 1 239 09-08-2026, 10:49 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 12,935 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,220 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,374 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,568 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,248 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,460 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 10,976 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,375 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,730 09-18-2020, 07:58 PM
Last Post: BowerR64
Users browsing this thread: 7 Guest(s)
