MSI-X support for KVM?
I'm running the ubuntu 18.04 image for the rockpro64. Whenever I try to run a virtual arm host, I always get this no matter what gic_version I use:
libvirtError: internal error: process exited while connecting to monitor: 2019-03-29T01:23:38.158817Z qemu-system-aarch64: -device pcie-root-port,port=0x8,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x1: MSI-X is not supported by interrupt controller
I've even tried passing pci=nomsi on the virtual.
Any advice here? I've done the updates, and am wondering if anyone has suggestions before I build the latest libvirt, virt-tools and qemu.
(03-28-2019, 07:31 PM)pfworks Wrote: I'm running the ubuntu 18.04 image for the rockpro64. Whenever I try to run a virtual arm host, I always get this no matter what gic_version I use:
I register bugreport about this issue here: https://bugs.launchpad.net/ubuntu/+sourc...ug/1832394
By the way, update to latest libvirt/qemu/virt-manager would not help as this issue is not fixed there. You need to use xml from Comment 2 of this bugreport, but then virtual machine would not start due to another bug: https://bugs.launchpad.net/ubuntu/+sourc...ug/1832395
  1024x600 resolution support monte 1 6,405 03-14-2021, 11:32 PM
Last Post: monte
  Encryption support rockfun 1 5,122 06-10-2020, 08:27 AM
Last Post: rockfun
  mainline kernel sound support Openwrt lucize 2 7,658 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 12,582 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Hyperion/Ambilight support? qwasy 5 13,213 03-30-2019, 04:40 PM
Last Post: antaril
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 5,815 11-01-2018, 08:33 AM
Last Post: danboid
  Most stable Linux rom and 1080p support? Nelly 2 7,094 10-08-2018, 12:30 PM
Last Post: Nelly
  Updates on Mainline Linux Support? hnaguski 0 4,173 09-11-2018, 08:16 PM
Last Post: hnaguski
  Kodi + Docker - what are the image options for Rock64 to support this? zarusz 0 4,126 05-20-2018, 01:41 AM
Last Post: zarusz
  How can I get a driver to support my USB wifi dongle Rocklobster 4 10,448 04-19-2018, 12:55 PM
Last Post: Rocklobster
