No Power Supply?
Received my new Pinebook. There doesn't seem to be a powersupply in the package, even though the shipping manifest shows "Power Supply: US" on it. Was the power supply a separate order item or ?
(05-26-2019, 12:13 PM)data_generating_event Wrote: Hi,
There should be a PSU with the Pinebook. Check packaging (not the blue plastic) again.
Hi Luke,
Thanks for the quick response. Nope, nothing there. It came as a box inside a yellow padded envelope, within a DHL plastic bag. Only other thing in the yellow padded envelope was the MMC upgrade I purchased.
Very strange ...
Please file a ticket: support.pine64.org/
Until they send you a PSU, you can still charge using a (3.5 mm?) barrel connector cable attached to standard mobile charger.
(05-29-2019, 01:23 AM)Wizzard Wrote: Until they send you a PSU, you can still charge using a (3.5 mm?) barrel connector cable attached to standard mobile charger.
Seriously, this is my absolute favourite thing with the Pinebook. Been sitting in a coffee shop for hours with it running off an Anker Powercore before without a hitch.
[ PHP Developer | Pinebook 1G | About me ]
  Pinebook wont turn on. Keeps blinking power light Taelsdoll 13 28,288 03-07-2020, 03:02 AM
Last Post: hoyd
  Can I Replace A Broken Power Plug? jschall 2 5,299 07-21-2019, 10:00 AM
Last Post: jschall
Photo Pinebook micro USB power input mod phuzy 4 8,971 05-20-2019, 09:17 PM
Last Post: phuzy
  Power supply replacement, but shipping is expensive kurai021 3 7,286 12-20-2017, 08:44 PM
Last Post: Siliconserf
  Inserting power supply resumes from suspend daid 8 13,198 08-10-2017, 11:17 PM
Last Post: daid
  UK Power Suggestions soupbowl 10 21,550 06-19-2017, 10:58 AM
Last Post: soupbowl
