newbie unable to reach the internet
I have a rockpro64 with 4Gb
I am running aarch64
Containers aarch64 (DockerCE & Kubernetes) [microSD / eMMC Boot] [0.7.9]
The system boots and I can see form "ip a" command shows lo:, eth0: and docker0:
however, when I run ifdown  eth0 i get unknown interface eth0
and so far I have been unsuccessful to reach the internet with ping or connect to the gateway my home router.
(05-06-2019, 11:19 PM)splash131 Wrote: I have a rockpro64 with 4Gb
You can only use ifup/ifdown if there is a corresponding entry in /etc/network/interfaces
A simpler way to go is to use nmtui to configure the interface...
   netplan is sometimes used instead of ifupdown : /etc/netplan/eth0.yaml or <networkInterface>.yaml
   you can use ifconfig to check the network
LMM.
Not sure how to close this but I got it working and connecting to the internet
I have an erro mesh network so it creates another network separate from my home router. I was not connected until I plugged into the eero. Now if I could learn how to get the WiFi component working ....
 If I wanted to use the home router I would have needed to use a different gateway address Big Grin
Thanks everyone for your help!
This is closed
  Unable to boot Armbian on new RockPro64 mooseball 5 13,601 07-14-2023, 08:59 AM
Last Post: rockjonn
  Unable to Run GNOME or KDE due to "dmidecode" segmentation fault rrs64 4 10,873 05-04-2022, 02:14 AM
Last Post: phoebepearl123
  Device unable to boot Lunix33 9 13,904 09-23-2021, 01:38 AM
Last Post: LMM
  PXE boot - unable to login LMM 2 5,630 04-22-2021, 02:59 PM
Last Post: LMM
  unable to boot from SDCard Charles Tarkowski 4 9,394 12-16-2020, 11:11 AM
Last Post: Charles Tarkowski
  Unable to synchronize Raid 0 NAS with OMV keuplat 0 3,019 11-10-2020, 05:47 PM
Last Post: keuplat
  Connection but No Internet Blake 5 11,643 10-25-2020, 02:13 PM
Last Post: Blake
Sad Noob connecting to internet splash131 3 7,929 09-01-2018, 02:28 AM
Last Post: evilbunny
