Dual monitor (LCD + HDMI) with Android
Is it possible to use the provided LCD TOUCH monitor AND (at the same time) an HDMI monitor?
Furthermore, if attaching an external mouse/keyboard, will it work if the touch is enabled to have dual control?
(03-21-2019, 12:15 AM)saviod Wrote: Is it possible to use the provided LCD TOUCH monitor AND (at the same time) an HDMI monitor?
The current 7" LCD panel can work together with HDMI under stock Android OS. By right should be enabled to have dual control.
Thanks for you reply!
How can i do it?
  Android images for RockPro64 BitAnnihilator 5 17,567 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,628 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 5,941 06-04-2022, 12:18 AM
Last Post: grobbs
  Slash TV Android for RockPro64 Wizzard 12 24,141 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 7,358 02-03-2022, 09:16 PM
Last Post: Johnmo89
  HDMI out? scanfff 0 4,219 08-13-2021, 10:47 PM
Last Post: scanfff
  Install Playstore on Android 8.1.0 Domo 14 44,974 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 24,819 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,495 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 48,769 02-13-2021, 12:52 AM
Last Post: chisteven
