Help Building Android Kernel
Hey,
Been trying to build the android kernel for the ROCKPRO64, as I've wanted to add support for a wifi usb dongle I'm using.
Using Kernel Source from ayufan: https://github.com/ayufan-rock64/android-kernel
The build is failing with:
drivers/built-in.o: In function `rk_pwm_config_v2': /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm rence to `rk3368_lcdc_cabc_status' /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm : relocation truncated to fit: R_AARCH64_CALL26 against undef tatus' /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm rence to `rk3368_lcdc_update_pwm' /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm : relocation truncated to fit: R_AARCH64_CALL26 against undef _pwm' Makefile:815: recipe for target 'vmlinux' failed
Thanks!
Actual Error: (initial post error was cut off)
drivers/built-in.o: In function `rk_pwm_config_v2': /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm-rockchip.c:352: undefined reference to `rk3368_lcdc_cabc_status' /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm-rockchip.c:352:(.text+0x104f4): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `rk3368_lcdc_cabc_status' /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm-rockchip.c:356: undefined reference to `rk3368_lcdc_update_pwm' /home/khoa/rock64/src/rockchip-android-kernel/drivers/pwm/pwm-rockchip.c:356:(.text+0x1052c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `rk3368_lcdc_update_pwm' Makefile:815: recipe for target 'vmlinux' failed make: *** [vmlinux] Error 1
  Android images for RockPro64 BitAnnihilator 5 18,103 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,788 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 6,125 06-04-2022, 12:18 AM
Last Post: grobbs
  Slash TV Android for RockPro64 Wizzard 12 25,029 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 7,641 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 46,088 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 25,447 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,740 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 50,156 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 6,127 11-20-2020, 04:15 AM
Last Post: Wizzard
