Rock64 +DAC + CPU Cooler
hello,
it's possible use the cpu cooler with DAC Audio on Rock64 ?
The TOSLINK out, work with OpenMediaVault 4 ?
Thanks in advance
(11-30-2018, 08:05 AM)maxves Wrote: hello,
Thanks in advance
the small fan type heatsink can be used with DAC board with ROCK64.
TOSLink works on Volumio, not sure on OMV.
Thank you.
For volumio, was it necessary to install additional drivers?
I tried in virtualbox, OMV AMD 64bit and the audio work fine, but with a standard audio out, no DAC.
  DeskPi case alternative for ROCK64 v1k699 2 13,412 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,704 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,592 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,293 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,502 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,052 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,946 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,734 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,092 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 8,079 06-08-2022, 12:44 AM
Last Post: Zoz
