Wifi problem
Lightbulb
I have a rock64 with openmediavault (arm64) on my emmc and I try to configure my wifi dongle but I can not
My wifi dongle -> https://www.aliexpress.com/item/Rocketek...15976.html
This is a RTL8811AU
root@rock64:~# lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0bda:a811 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I tried on Windows 10, the wifi key has a blue led flashing. And when I connect to my rock64 there is no blue LED blinking and I can not configure it. I do not know how to do.
How to do it since openmediavault please???
Best regards
[  459.768070] usb 2-1: new high-speed USB device number 4 using ehci-platform
[  459.901195] usb 2-1: New USB device found, idVendor=0bda, idProduct=a811
[  459.901922] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  459.902674] usb 2-1: Product: 802.11ac WLAN Adapter
[  459.903200] usb 2-1: Manufacturer: Realtek
[  459.903645] usb 2-1: SerialNumber: 00e04c000001
(11-27-2018, 08:36 AM)Nether494 Wrote: This is a RTL8811AU
Because it's an 802.11ac device there are no drivers for it in the kernel, you will unfortunately need to find drivers and compile and install them.
I have a deb package for a similar driver but I was never able to get it to build on 32bit omv.
Okay I see. My wifi dongle is not appropriate. If I buy the same wifi dongle that the official website Pine64 is good? will it work with OMV?
Best regards
(11-27-2018, 06:21 PM)Nether494 Wrote: Okay I see. My wifi dongle is not appropriate. If I buy the same wifi dongle that the official website Pine64 is good? will it work with OMV?
Same problem, you will need to build drivers for nearly all 802.11ac devices. A quick google of rtl8811au brought up the following driver on github.
https://github.com/sloretz/rtl8811au
Hi thanks !
root@rock64:/usr/src/rtl8811au# make
make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1/build M=/usr/src/rtl8811au  modules
make[1]: Entering directory '/usr/src/linux-headers-4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1'
Makefile:645: arch/aarch64/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/aarch64/Makefile'.  Stop.
make[1]: Leaving directory '/usr/src/linux-headers-4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1'
Makefile:1551: recipe for target 'modules' failed
make: *** [modules] Error 2
Impossible to make this driver, I try to find a another git
Best regards
Hi thanks !
Best regards
I forgot how painful it is, you need to set ARCH=arm64, setting -j4 will speed things up as it'll use all cores, and finally you have to disable various warnings because the compiler will fail there too.
Hi thanks !
Best regards
Please excuse me I am a beginner. I try to do the best I can
root@rock64:/usr/src/rtl8811au# sudo make clean
cd hal/OUTSRC/ ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
cd hal/OUTSRC/ ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd hal/led ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd hal ; rm -fr */*/*.mod.c */*/*.mod */*/*.o */*/.*.cmd */*/*.ko
cd hal ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
cd hal ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd core/efuse ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd core ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd os_dep/linux ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd os_dep ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd platform ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
rm -fr .tmp_versions
root@rock64:/usr/src/rtl8811au# make ARCH=arm64 -j4
make ARCH=arm64 CROSS_COMPILE= -C /lib/modules/4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1/build M=/usr/src/rtl8811au  modules
 CC [M]  /usr/src/rtl8811au/core/rtw_cmd.o
 CC [M]  /usr/src/rtl8811au/core/rtw_security.o
 CC [M]  /usr/src/rtl8811au/core/rtw_debug.o
 CC [M]  /usr/src/rtl8811au/core/rtw_io.o
 CC [M]  /usr/src/rtl8811au/core/rtw_ioctl_query.o
 CC [M]  /usr/src/rtl8811au/core/rtw_ioctl_set.o
/usr/src/rtl8811au/core/rtw_security.c: In function 'aes_cipher':
/usr/src/rtl8811au/core/rtw_security.c:1598:5: warning: this 'for' clause does not guard... [-Wmisleading-indentation]
error, forbidden warning:rtw_security.c:1598
    for (j = 0; j < 8; j++)
/usr/src/rtl8811au/core/rtw_security.c:1601:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'for'
 payload_index = hdrlen + 8;
/usr/src/rtl8811au/core/rtw_security.c: In function 'aes_decipher':
/usr/src/rtl8811au/core/rtw_security.c:1984:5: warning: this 'for' clause does not guard... [-Wmisleading-indentation]
error, forbidden warning:rtw_security.c:1984
/usr/src/rtl8811au/core/rtw_security.c:1987:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'for'
scripts/Makefile.build:277: recipe for target '/usr/src/rtl8811au/core/rtw_security.o' failed
make[2]: *** [/usr/src/rtl8811au/core/rtw_security.o] Error 1
make[2]: *** Waiting for unfinished jobs....
Makefile:1474: recipe for target '_module_/usr/src/rtl8811au' failed
make[1]: *** [_module_/usr/src/rtl8811au] Error 2
Best regards
Hi thanks !
Best regards
Best regards
Long story short, I built the driver but it produced kernel modules for the RTL8821AU, the steps I took are as follows:
nano Makefile and add the following lines:
EXTRA_CFLAGS += -Wno-unused-variable
EXTRA_CFLAGS += -Wno-unused-value
EXTRA_CFLAGS += -Wno-unused-label
EXTRA_CFLAGS += -Wno-unused-parameter
EXTRA_CFLAGS += -Wno-unused-function
EXTRA_CFLAGS += -Wno-ignored-qualifiers
EXTRA_CFLAGS += -Wno-misleading-indentation
EXTRA_CFLAGS += -Wno-implicit-function-declaration
Then towards the bottom replace the following:
$(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C $(KSRC) M=$(shell pwd)  modules
with
$(MAKE) ARCH=arm64 -j4 CROSS_COMPILE=$(CROSS_COMPILE) -C $(KSRC) M=$(shell pwd)  modules
Then run make
(11-27-2018, 07:33 PM)evilbunny Wrote: Same problem, you will need to build drivers for nearly all 802.11ac devices. A quick google of rtl8811au brought up the following driver on github.
Hi thanks !
Best regards
Best regards
with
Then run make
I have a error again
make ARCH=arm64 -j4 CROSS_COMPILE=/home/android_sdk/Rockchip/Rk3188/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi- -C /home/android_sdk/Rockchip/Rk3188/kernel M=/usr/src/rtl8811au  modules
make[1]: *** /home/android_sdk/Rockchip/Rk3188/kernel: No such file or directory.  Stop.
Makefile:1554: recipe for target 'modules' failed
This is my makefile -> https://pastebin.com/X4YSEChB
Best regards
  problem with debian emmc boot G4zCDzWb 10 11,956 11-01-2024, 04:32 PM
Last Post: bits
  Rock64 Debian 11 (Bullseye) install problem jbize 15 21,712 10-12-2023, 05:14 PM
Last Post: tpaul
  External hard drive problem k8Va 17 33,972 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 4,936 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 10,235 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 7,952 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 6,697 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,504 03-26-2019, 07:28 PM
Last Post: Poincare
  ROCK64 Kernel compilation problem cao 0 3,619 01-21-2019, 01:21 AM
Last Post: cao
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 6,654 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
