Tool to Control Fan - fanctl
#91
I can't get this to install for the life of me.
Installed dependencies, created symlink, then:
cat <</usr/bin/lua5.3 >> /etc/luarocks/config.lua > variables = { >     UNISTD_INCDIR   = "/usr/include", >     STAT_INCDIR     = "/usr/include/$( gcc -dumpmachine )", >     TYPES_INCDIR    = "/usr/include/$( gcc -dumpmachine )", >     LUALIB_INCDIR   = "/usr/include/lua5.3", >     LAUXLIB_INCDIR  = "/usr/include/lua5.3", >     LUA_INCDIR      = "/usr/include/lua5.3", >     LUA53_LIBDIR    = "/usr/lib/$( gcc -dumpmachine )" > } > /usr/bin/lua5.3
I then ran:
luarocks build https://raw.githubusercontent.com/tuxd3v/ats/master/ats-0.1-6.rockspec
And I got this output:
Warning: variable CFLAGS was not passed in build_variables gcc -c -fPIC -Wall -Werror -O3 -g -I/usr/include/lua5.3  -o src/sleep.o src/sleep.c gcc -shared -Wl,-soname,sleep.so.0 -llua5.3  -o sleep.so.0.1 src/sleep.o install --preserve-timestamps --owner=root --group=root --mode=750 --target-directory=/usr/sbin src/fanctl install --preserve-timestamps --owner=root --group=root --mode=640 --target-directory=/lib/systemd/system systemd/fanctl.service if [ ! -d /usr/lib/aarch64-linux-gnu/lua/5.3 ];then \ mkdir -p /usr/lib/aarch64-linux-gnu/lua/5.3; \ fi install --preserve-timestamps --owner=root --group=root --mode=640 --target-directory=/usr/lib/aarch64-linux-gnu/lua/5.3 sleep.so.0.1 if [ -L /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so ];then \ rm -f /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so; \ fi ln -s /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so.0.1 /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so systemctl enable fanctl ats 0.1-6 is now installed in /usr/local (license: See License..)
When I run
service ats status
I get:
ats.service - ATS - Active Thermal Service   Loaded: loaded (/lib/systemd/system/ats.service; enabled; vendor preset: enab led)   Active: activating (auto-restart) (Result: exit-code) since Tue 2018-11-20 12 :11:19 EST; 5s ago Main PID: 8548 (code=exited, status=1/FAILURE) Nov 20 12:11:19 DietPi systemd[1]: ats.service: Main process exited, cod e=exited, status=1/FAILURE Nov 20 12:11:19 DietPi systemd[1]: ats.service: Unit entered failed stat e. Nov 20 12:11:19 DietPi systemd[1]: ats.service: Failed with result 'exit -code'.
I'm not sure what I'm doing wrong, could someone help?
(11-20-2018, 11:17 AM)Drago Wrote: I can't get this to install for the life of me.
Hello Drago,
when you issue:
cat <<HERE >> /etc/luarocks/config.lua variables = {    UNISTD_INCDIR   = "/usr/include",    STAT_INCDIR     = "/usr/include/$( gcc -dumpmachine )",    TYPES_INCDIR    = "/usr/include/$( gcc -dumpmachine )",    LUALIB_INCDIR   = "/usr/include/lua5.3",    LAUXLIB_INCDIR  = "/usr/include/lua5.3",    LUA_INCDIR      = "/usr/include/lua5.3",    LUA53_LIBDIR    = "/usr/lib/$( gcc -dumpmachine )" } HERE
You need to press enter after Shy
If you don't succeed, then try the master version:
luarocks build https://raw.githubusercontent.com/tuxd3v/ats/master/ats-master-0.rockspec
It will be the next stable version..
Hello Drago,
when you issue:
I tried installing the master version and still no luck.
(11-20-2018, 03:31 PM)Drago Wrote: I tried installing the master version and still no luck.
Ok, no problem,  Shy
When you install the master branch version, what is the output you get?
I have tested with debian and with ubuntu versions, you are in DietPi, its nice if you could help me, so that I also improve compatibility with DietPi [Image: wink.png]
EDIT: Also what do you get in the logs?
Check with this command:
journalctl -u ats
Ok, no problem,  Shy
journalctl -u ats
Here's the output after trying to install the master version:
Cloning into 'ats'... remote: Enumerating objects: 16, done. remote: Counting objects: 100% (16/16), done. remote: Compressing objects: 100% (15/15), done. remote: Total 16 (delta 1), reused 6 (delta 0), pack-reused 0 Receiving objects: 100% (16/16), 95.96 KiB | 0 bytes/s, done. Resolving deltas: 100% (1/1), done. Warning: variable CFLAGS was not passed in build_variables gcc -c -march=armv8-a+crc -mtune=cortex-a72.cortex-a53 -fPIC -Wall -Werror -O3 -g -I/usr/include/lua5.3  -o src/ats.o src/ats.c gcc -shared -Wl,-soname,ats.so.0 -llua5.3  -o ats.so.0.2 src/ats.o Install ATS Tool ..................: ats in /usr/local/sbin Install ATS Service File ..........: ats.service in systemd Remove previous ATS Library .......: ats.so.* from /usr/local/lib/lua/5.3 Install new ATS Library ...........: ats.so.0.2 in /usr/local/lib/lua/5.3 Create soname symLink .............: ats.so in /usr/local/lib/lua/5.3 Starting ATS Service.. \u25cf ats.service - ATS - Active Thermal Service   Loaded: loaded (/lib/systemd/system/ats.service; enabled; vendor preset: enab led)   Active: activating (auto-restart) (Result: exit-code) since Tue 2018-11-20 20 :51:53 EST; 1s ago  Process: 16998 ExecStart=/usr/local/sbin/ats (code=exited, status=1/FA ILURE) Main PID: 16998 (code=exited, status=1/FAILURE) Nov 20 20:51:53 DietPi systemd[1]: ats.service: Failed with result 'exit -code'. Makefile:46: recipe for target 'install' failed make: *** [install] Error 3 Error: Build error: Failed installing.
And here's what I get in the logs:
Nov 20 20:58:43 DietPi ats[17492]: exit 1 Nov 20 20:58:43 DietPi systemd[1]: ats.service: Main process exited, code=exited, status=1/FAILURE Nov 20 20:58:43 DietPi systemd[1]: ats.service: Unit entered failed state. Nov 20 20:58:43 DietPi systemd[1]: ats.service: Failed with result 'exit-code'. Nov 20 20:58:51 DietPi systemd[1]: ats.service: Service hold-off time over, scheduling restart. Nov 20 20:58:51 DietPi systemd[1]: Stopped ATS - Active Thermal Service. Nov 20 20:58:51 DietPi systemd[1]: Started ATS - Active Thermal Service. Nov 20 20:58:51 DietPi ats[17503]: getConditions: Warning, Values { THERMAL0_CTL, THERMAL1_CTL, FAN_CTL }: /sys/class/thermal/thermal_zone0/temp, /sys/class/ thermal/thermal_zone1/temp, ERROR
Thanks,[Image: shy.png]
Yup, You need to update your kernel..that version doesn't get exported to SysFs the needed controls..
I don't know if you have access to this Kernels, but try it:
apt-get update apt-get install linux-image-4.4.138-1097-rockchip-ayufan-gb5128c0a1684 linux-headers-4.4.138-1097-rockchip-ayufan-gb5128c0a1684 linux-firmware-image-4.4.138-1097-rockchip-ayufan-gb5128c0a1684 reboot
Then, reboot,
After reboot it should start automatically..
You can stop it,
service ats stop
 and run a test:
ats --test
To see timers and power it applies to fan, also temps..when done crtl+C
and start service again:
service ats start service ats status
Then, reboot,
Will updating the kernel mess with my DietPi install?
Nevermind, I was able to update the kernel and it works now! Thanks for your help!
Here's the output from test:
Stopping for[ seconds ]............... 10 CPU Temperature[ max 70 °C ].......... 60 GPU Temperature[ max 70 °C ].......... 60 Fan PWM Duty Cycle value[ 0 - 255 ]... 190 -------------------- Running for[ seconds ]................ 10 CPU Temperature[ max 70 °C ].......... 42 GPU Temperature[ max 70 °C ].......... 41 Fan PWM Duty Cycle value[ 0 - 255 ]... 62 -------------------- Stopping for[ seconds ]............... 90 CPU Temperature[ max 70 °C ].......... 42 GPU Temperature[ max 70 °C ].......... 41 Fan PWM Duty Cycle value[ 0 - 255 ]... 0 --------------------
And the service running:
ats.service - ATS - Active Thermal Service   Loaded: loaded (/lib/systemd/system/ats.service; enabled; vendor preset: enab led)   Active: active (running) since Tue 2018-11-20 22:31:04 EST; 5s ago Main PID: 2593 (lua)    Tasks: 1 (limit: 4915)   CGroup: /system.slice/ats.service           \u2514\u25002593 lua /usr/local/sbin/ats Nov 20 22:31:04 DietPi systemd[1]: Started ATS - Active Thermal Service.
The fan is kind of loud actually, any advice on damping the sound?
(11-20-2018, 09:19 PM)Drago Wrote: The fan is kind of loud actually, any advice on damping the sound?
For Now, its only possible editing : '/usr/local/sbin/ats'
In future releases, will be there a config file '/etc/ats.conf'
Changing the profile will lower the fan speed..
You can change line 68, of file  '/usr/local/sbin/ats'
change:
FANSPEC                         = "profile1"
for "profile2"
or even "profile3"
it will have a less aggressive power output..
What are the characteristics of your fan?
(11-19-2018, 03:28 PM)tuxd3v Wrote:
(11-18-2018, 01:59 PM)Girbur Wrote: Got it sorry
No problem,
You welcome Shy
In fact I have not yet documented it, sorry for that.
Choose if you want one of those 3 profiles,
And adapt the timers in the line 97, in this function :
setTriggers     = function( self, x )
You will see  that for each range of temps are there some timers.
Quiet(the fan is stoped by this time in Seconds)
Run( The fan will run for that specified time in seconds )
You only need to change and then start ats again, and test the best option for your setup [Image: shy.png]
Hey,
ok so i´ve played arround with these settings a bit but im not sattisfied with the result i produced Big Grin
what i want to do is use Profile 3 or what ever and then i want the fan to always run but kinda slow so. this way it cools and is not as loud.
is that possible? if yes could you give me the numbers i need to put in and where? Smile
Greetings
Steffen
p.s. i think i found it my selfe after i wrote this post Big Grin
is this correct to change this setting: MAX_FAN_PWM?
I changed it to 150 and the fan is mutch quieter.
or am i wrong and did something fatal? Big Grin
(11-21-2018, 01:32 PM)stFfn Wrote: p.s. i think i found it my selfe after i wrote this post Big Grin
That is one way of limiting without changing too much [Image: shy.png]
The PWM curve by Interpolated method is:
  PWM Fan Control Python Script superbox 0 3,319 02-04-2022, 10:02 PM
Last Post: superbox
