Screen Overscan Fix?
So have some screen overscan and atm have a 1024x768 res cause it fits perfect in screen, when I change to 1080 there is too much overscan, cant see menu bar and all sides of screen are overscanned, Im no dev but have half a brain, with some simple instructions or pointing out where to go, I'm sure ill manage. ATM image is horrible, 1080 looks awesome but not at all functional, plz help
Already checked this page for fix, to no avail  lxrandr page
Already tried all settings in TV
rock64@rockpro64:~$ xrandr -q
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192
HDMI-1 connected primary 1024x768+0+0 708mm x 398mm
  1920x1080     60.00    50.00    59.94    30.00    24.00    29.97    23.98
  1920x1080i    60.00    50.00    59.94
  1280x720      60.00    50.00    59.94
  1024x768      60.00*
  1440x480i     59.94
  800x600       60.32
  720x576       50.00
  720x576i      50.00
  720x480       60.00    59.94
  720x480i      60.00    59.94
  640x480       60.00    59.94
DP-1 disconnected
rock64@rockpro64:~$ xrandr --prop
    EDID:
        00ffffffffffff004f4d300001000000
        101b0103806036780acf74a3574cb023
        09484c21080001010101010101010101
        01010101010108e80030f2705a80b058
        8a00c48e2100001e023a801871382d40
        582c4500c48e2100001e000000fc004c
        45442054560a202020202020000000fd
        00173d0f883c000a2020202020200129
        020334f15105030112131416071f2022
        02061115100426090707150750830100
        006e030c002000004420008001020304
        e30e60618c0ad08a20e02d10103e9600
        c48e210000188c0aa01451f01600267c
        4300c48e210000980000000000000000
        00000000000000000000000000000000
        000000000000000000000000000000ec
    hue: 50
        range: (0, 100)
    saturation: 50
        range: (0, 100)
    contrast: 50
        range: (0, 100)
    brightness: 50
        range: (0, 100)
    hdmi_output_mode_capacity: 15
        range: (0, 15)
    hdmi_color_depth_capacity: 1
        range: (0, 255)
    hdmi_output_colorimetry: None
        supported: None, ITU_2020
    hdmi_output_format: output_rgb
        supported: output_rgb, output_ycbcr444, output_ycbcr422, output_ycbcr420, output_ycbcr_high_subsampling, output_ycbcr_low_subsampling, invalid_output
    hdmi_output_depth: 24bit
        supported: Automatic, 24bit, 30bit
  1024x768      60.00*
  1440x480i     59.94
  800x600       60.32
  720x576       50.00
  720x576i      50.00
  720x480       60.00    59.94
  640x480       60.00    59.94
DP-1 disconnected
    hue: 50
        range: (0, 100)
    saturation: 50
        range: (0, 100)
    contrast: 50
        range: (0, 100)
    brightness: 50
        range: (0, 100)
    Content Protection: Undesired
        supported: Undesired, Desired, Enabled
This one in the bottom actually made me have to reflash sdcard, just broke the board:
$ xrandr --output HDMI1 --transform 0.80,0,-35,0,1.04,-19,0,0,1
maybe it can be manually configured somewhere else, just not so obvious for the layman.
  I had a overscan problem with the rock64/rockpro64 that sounds like yours. Also I had a distorted picture with 1920x1080 because the edid of my canoxTV did not match the pixelclock of the rock64. I ended with a custom edid-file that brought me a clean screen but no audio over hdmi, cause my monitor is gone into HDMI-DVI mode. But you can try one of my working modeline on xorg.conf.d if you like:
Section "Monitor"
 Identifier "HDMI-1"
 Option "PreferredMode" "1920x1080g"
 Modeline "1920x1080g" 136.75  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync
 Modeline "1366x768"   72.00  1366 1380 1436 1500  768 769 772 800 +hsync +vsync
 Modeline "1680x1050"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync
EndSection
The HDMI-DVI-mode problem with audio in  a custom edid I fixed in
https://gitlab.com/hunderteins/linux-ker...7bc3ac56ac
Everything is better than 1024x768.
Thanks will give it a try, give some feedback, thanks
  hello i want to drive an edp screen with my rockpro64 hannescam 0 2,084 10-20-2022, 01:22 PM
Last Post: hannescam
  Flickering screen Indeed 0 2,939 03-23-2020, 07:38 AM
Last Post: Indeed
  Screen flicker and tearing RussianNeuroMancer 0 3,254 06-12-2019, 03:57 AM
Last Post: RussianNeuroMancer
  so installed minimal then xubuntu, major screen tearing. Martronic 3 6,567 12-28-2018, 09:16 AM
Last Post: elatllat
  Small screen for linux use? Wirenfeldt 3 7,698 08-29-2018, 12:07 PM
Last Post: elatllat
