Case options?
Most cases for the A64 will fit the RockPro64, correct?
Does anyone know of any case options with a fan?
This is the only one I've found: https://www.c4labs.com/product/zebra-cla...e-options/, but I'm not sure it will fit the RockPro64. Has anyone tried this case?
(11-07-2018, 03:09 PM)joshuam Wrote: Most cases for the A64 will fit the RockPro64, correct?
Won't work because the Pro has 4 USB ports (2x USB 2.0 / 1x USB 3.0 + 1x USB -C ).
There is the ABS case and there will be a fancy all-metal black case for the Pro out at some point.
I have the touchscreen case, and I have to tell you, if you ever see that graphene heatsink, it means you'll be lucky to fit a mid-profile heatsink under.  I have the tall profile with fan and I had to cut a hole with my dremel and put a fan guard over it.  The Pine store sells some really clean/professional looking cases ( the ABS ones ), but they're difficult to get back into without damaging the plastic.
  NAS case HDD power cable failure (buck failure) ashleymills 1 4,718 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 3,089 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 5,028 12-04-2021, 05:14 AM
Last Post: Goffi
  RP64 TV box case with wifi Wizzard 2 6,652 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 9,115 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 3,544 01-09-2021, 05:24 PM
Last Post: kuleszdl
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 22,682 01-05-2021, 05:05 PM
Last Post: kuleszdl
  Release CAD files for NAS case or parts of it? diizzy 5 11,075 08-13-2020, 04:50 AM
Last Post: diizzy
  Best location for adhesive wifi antennas with NAS case callegar 1 5,538 02-17-2020, 12:40 PM
  RP64 NAS Case, 1 month in Tim Jones 1 5,115 07-29-2019, 04:16 PM
Last Post: Luke
