benefits of eMMC?
Question
I'm considering buying a RockPro64 to use as a NAS and general server, I saw that one could buy eMMC modules to use as internal memory for the board. I have a few questions here:
  • What is the benefit of using eMMC rather than SD card? Speed, longer lifetime or the storage?
  • How is the eMMC module attached to the board? I couldn't identify an obvious slot or similar connection.
  • What is the purpose of the USB adapter, is it to "burn" the OS image to the eMMC or do you need it to attach the eMMC to the board?
Yes, Yes & not really - 64GB on eMMC is trivially smaller than 64GB on SD card due to storage reserved for error allocation.
See item 14.
To burn the image to the eMMC. (It does simplify things but it is not essential.)
Thanks a lot for the answer!
There seems to be something wrong with the wiki, I'm redirected to the store when I try to click the link, but I think I found a low res picture of the board layout.
Is it this one? So to the right (in this picture) of the PCIe slot? (It does look very much like the end of the USB adapter, maybe I should have seen that  Rolleyes
high res picture
Still seems that there is something wrong with the links to the wiki, I keep being redirected to the shop, but I think I understand how it looks.
Sorry about the weird image-tag it seems I got the image data instead of the link. Apparently one cannot edit one's posts, hopefully some moderator can remove the tag Sad
(10-02-2018, 01:24 AM)SirSkorpan Wrote: Still seems that there is something wrong with the links to the wiki, I keep being redirected to the shop, but I think I understand how it looks.
Done. Thanks for prompting us Smile
  Can i use this Emmc for Rockpro 64 Supratec 0 2,740 09-02-2023, 06:38 AM
Last Post: Supratec
  Pad to level Emmc like the PineBook Pro JessicaQ 0 3,885 08-18-2022, 12:28 PM
Last Post: JessicaQ
  eMMC can't be recognize after 6 months idle seanlee 10 20,105 12-24-2019, 04:35 AM
Last Post: abdel
  Emmc issue? stuartiannaylor 6 13,069 08-16-2019, 06:41 AM
Last Post: stuartiannaylor
  eMMC support themyshop 2 7,411 09-24-2018, 06:20 AM
Last Post: themyshop
  Foresee NCEMASLG-64G 64 GB eMMC module unreadable lucho 7 14,629 08-05-2018, 03:58 AM
Last Post: paradise
