09-24-2018, 10:10 PM
How to modify IMEI on android os?is there any tools to do this?
How to modify IMEI
09-24-2018, 11:53 PM
12-07-2018, 10:47 AM
Probably no one will tell you here because, as I understand it, changing the IMEI is illegal.
If the phone works, why change it. If the IMEI is blocked then the phone is probably stolen... Just return it and buy your own.
11-06-2019, 03:55 AM
(12-07-2018, 10:47 AM)nateliv Wrote: Probably no one will tell you here because, as I understand it, changing the IMEI is illegal.It is legal where i live. (12-07-2018, 10:47 AM)nateliv Wrote: If the phone works, why change it.For the privacy reasons. IMEI is a perfect way to track a person, even w/o having access to the service provider's system.
11-18-2019, 07:38 PM
(This post was last modified: 11-18-2019, 07:40 PM by Danct12.
Edit Reason: Added quote to the target response.
(12-07-2018, 10:47 AM)nateliv Wrote: Probably no one will tell you here because, as I understand it, changing the IMEI is illegal. It's still illegal in some countries, which may also includes where this forum/server is hosted.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
11-19-2019, 03:27 AM
(11-18-2019, 07:38 PM)Danct12 Wrote:(12-07-2018, 10:47 AM)nateliv Wrote: Probably no one will tell you here because, as I understand it, changing the IMEI is illegal. This is irrelevant since changing IMEI is different from discussing how to change IMEI.
11-19-2019, 02:39 PM
(11-19-2019, 03:27 AM)L29Ah_ Wrote:(11-18-2019, 07:38 PM)Danct12 Wrote:(12-07-2018, 10:47 AM)nateliv Wrote: Probably no one will tell you here because, as I understand it, changing the IMEI is illegal. Is your Android install rooted? There's an Xposed modules "IMEI Changer" that can do this. |
| How to modify HOSTS file | rvalecruz | 1 | 5,706 |
02-02-2017, 12:53 AM Last Post: MarkHaysHarris777 |
| How to modify *.conf files? | gbjensen | 7 | 17,121 |
07-09-2016, 01:05 AM Last Post: gbjensen |
