rock64 hdd from usb3.0
I would like to ask is it possible to power some HDD from USB 3.0 on Rock64 sbc ?
I mean without external power - just from usb - probably it should run fine with some external enclosure and 2.5" 5400rpm HDD or SSD ?
(08-21-2018, 07:35 AM)baszek Wrote: Hi,
USB 3.0 yes, because it can deliver 900mha which will suffice for a 2.5" drive.
So you are sure that Rock64 can deliver that ~1A to usb 3.0 - should be enough to run even 7200rpm drive.
Are you asking for USB 3.0 specification? if yes, read this. The PSU that you ought to use for the R64 is a 3A 5V, so plenty of headroom to power a USB 3.0 2.5" SSD or HDD. Do read tkaiser's post on armbian detailing the Rock64 power usage with a USB 3.0 drive attached (as well as the JMicron JMS578 bridge sold in the store).
I've found with my 3 Rock64's with a single Apacer SSD each that SSD boot is unreliable on 2 of them with USB3. 1 of the Rock64's is fine, I've tried switching drives.
SSD boot when drive plugged into USB2 is very reliable.
Using a powered USB 3 hub is reliable though.
Disk performance is faster with USB3.
  Sleep on Rock64 Grecor9090 1 5,121 10-26-2020, 07:42 PM
Last Post: KNERD
Question Does the Rock64 single board computer (1, 2 or 4 GB ram) have a PCie slot? IP_Proxy 5 11,380 04-29-2019, 08:19 PM
  Shipping time on a Rock64 package to the US jhereg 14 31,761 10-17-2018, 11:36 AM
  Rock64 crashes(or goes into suspend maybe)everytime system idles Sauromayne 3 9,006 12-14-2017, 08:23 PM
Last Post: dkryder
