UK PSU for rock64
Question
One of the main reasons I bought a rock64 was the promise of being able to play 4K videos yet I have so far not managed to go much longer than 5m of 4K video playback before kodi freezes or reboots my rock64. Before I attached a heatsink to its CPU it would struggle to last even 1m when playing 4K videos under kodi so now I presume it is my PSU at fault because no-one else seems to be having such issues with kodi.
I am currently using an atolla 5V/3000mA PSU (model BYX-0503000B) that I bought off Amazon. It seems to work OK but I don't have a multimeter or anything to check that it is actually supplying the claimed output. I would prefer not to order a PSU from pine because it costs a lot to have things posted from the US to the UK and also it seems that the PSU they sell is a US PSU that requires an adapter to plug into a UK mains socket. I would rather get a PSU with a UK plug that doesn't require an adapter, ideally.
If there are any UK rock64 users reading this that have a working 'native' PSU and can confirm you can use kodi to watch 4K videos for more than 10m (ideally I'd be able to watch feature length 4K films without any reboots or freezes) then please tell me the make and model of your PSU and where you bought it from.
Thanks!
I've ordered one of these, a KFD Universal 5V 3A Power Adapter
https://www.amazon.co.uk/dp/B07CXHTK4W/r...11_TE_item
I'll report back after I've had chance to test it.
(08-20-2018, 12:21 PM)danboid Wrote: I've ordered one of these, a KFD Universal 5V 3A Power Adapter
10meter is a long cable and the voltage drop sometimes can make the ROCK64 board run in unstable stage. Please make sure that the power supply power cable is thick enough and has low resistor value to minimize the voltage drop.
I'm getting the same sort of results with KFD PSU as I was with the atolla so I've had to bite the bullet and order not one but 2 official PSUs (with UK adapters).
Just for point of reference, I like this PSU coupled with an adapter from microusb to barrel. It seems to provide the maximum supported power to the board. I've used the same on my RPI as well without the barrel adapter. I'm not sure if you can find it for the UK, however.
https://www.amazon.com/Optimum-Orbis-Des...wer+supply
  DeskPi case alternative for ROCK64 v1k699 2 13,646 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,850 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,719 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,950 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,679 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,201 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 22,258 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,897 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,276 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 8,232 06-08-2022, 12:44 AM
Last Post: Zoz
