virtual machine, arm host
is there any virtual machine manager that will work on an arm host?
I realize that would probably mean arm client machines would perform much better if they were for arm architecture as well (implied)
I've attached a couple PDFs relevant to your question. Both documents refer specifically to the latest ARM revision armv8.4. The short answer is yes, virtualization is possible. The first doc is the most direct response to your question, providing more or less a high-level overview of the differing hypervisors (KVM vs. Xen) you'll want to explore.
The second doc is only tangentially related to your question, but I think you'll find it interesting anyway if you're into virtualization. It explores Nested Virtualization Extensions for ARM processors (dubbed "NEVE" by the authors), which has some pretty phenomenal implications. Again, it's not so pertinent to your question, but it's a nifty read to keep on hand. ¯\_(ツ)_/¯
http://cloud.tapatalk.com/s/5b68d399b800...100_en.pdf
http://cloud.tapatalk.com/s/5b68d654338b...7_neve.pdf
Sent from my Pixel 2 XL using Tapatalk
  Partitioning encrypted CCC Carbon Copy Cloner AND setting up Time Machine on HDD vidin 0 3,507 05-10-2020, 01:08 PM
Last Post: vidin
  USB 3.0 Host Controller crashes when accessing several devices simultaneously h31 10 27,894 11-10-2018, 07:26 PM
Last Post: Trash_Can_Man
Question Completely new to this - Can I use ROCK64 as basic Linux desktop machine @ 3840x1600? King_V 4 10,339 04-20-2018, 08:48 AM
Last Post: King_V
  I'm installing winxp by qemu virtual machine. fbms 2 6,584 09-03-2017, 07:08 PM
Last Post: fbms
