Compiling on the Sopine Cluster
i wanna use  a rockpro64 with gentoo. Now i thought about using a sopine cluster as a compile machine. I am concerned about the eMMC/SD storages.
I doubt they survive heavy usage very long. Has anyone experience with this?
Since there is a LAN output on the clusterboard itself i thought about adding an HDD with a switch. Is it possible to reduce the usage off the sd card this way?
I really wanna try this project but have no similar experience yet with similar things.
If anyone is interested i have here a short summery what i plan to do in detail.
https://pad.stratum0.org/p/khaosgrillesS...sdayDevice
Thank you
Khaosgrille
(07-10-2018, 06:33 AM)khaosgrille Wrote: Hi,
Thank you
Khaosgrille
I wouldn't try that on SD or eMMC cards but using network I see no problem.
You could use a NAS that talks NFS and use that as storage or use node 1 with a ramdisk if your stuff isn't that big.
Didn't do any good testing because my board is connected to a 100Mbit switch but I will test node->node speed somewhere today.
Small update, I'm getting about 85MB/s on FreeBSD a.t.m. but there are still some link drop issues (you do not notice as much in traffic but are pretty damn annoying as console warning)..
Thank you for your information. I will do some practical testing.
Greetings,
Khaosgrille
  Selling Clusterboard + 4 sopine xblack86 7 15,065 09-26-2022, 03:09 AM
Last Post: poVoq
  Buy Cluster and Compute Modules jpotter 1 5,734 01-10-2022, 04:01 PM
Last Post: dcdc
  SOPine modules stay off at reboot? PeterKeuning 32 67,993 08-17-2021, 11:11 AM
Last Post: renze
  What's the point of a cluster? guenther 2 8,246 04-07-2021, 10:49 AM
Last Post: guenther
  Add ordinary so-dimm memory to cluster slot? fxSol 1 6,679 03-02-2021, 03:54 AM
Last Post: poVoq
  Is my wooden desk a safe surface to test the cluster board on? ollehar 6 15,305 12-28-2020, 09:41 AM
Last Post: robocone
  Building a new cluster with external storage hvdkooij 2 8,440 11-20-2020, 07:44 AM
Last Post: hvdkooij
  Compatibility between RPi Module and Cluster board leperotero 1 6,196 11-03-2020, 03:40 PM
Last Post: poVoq
  sopine socket power problem cgiraldo 1 5,697 06-17-2020, 02:10 PM
Last Post: cgiraldo
  Is there any way to get a video output from a cluster module? ollehar 4 11,492 06-16-2020, 12:34 PM
Last Post: ollehar
