[Archived] Initial Linux release from ayufan (0.6.XX)
#41
GPIOs work
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
#42
Hi All
Just loaded up
bionic-lxde-rockpro64-0.7.3-1040-arm64.img
Everything appears to be working except the mouse pointer does not show up.
If you right click you get popups
occasionally as you move the mouse around you see the menubar items flicker. If you judge it right you can bring up the individual menu icons.
Has anyone else seen this.
I have done the engineering mode and removed the resistor but that is to do with the pci power problem.
#43
(07-07-2018, 11:31 AM)mikeD Wrote: Hi All
Just loaded up
Yep, rendering 'planes' are wrong.
#44
:-) OK
#45
This is how you fix desktop, including mouse cursor:
sudo apt-get update sudo apt-get install xserver-xorg-video-armsoc
Reboot and everything should work as expected.
[edit] to get sound working via HDMI:
`pacmd set-default-sink alsa_output.platform-hdmi-dp-sound.stereo-fallback
Enjoy 1080p youtube (in firefox) Wink
#46
thats great many thanks.
I have another problem now which is unexplained.
If I burn the image to sd the rockpro boots no problem.
As soon as I either shutdown or do a sudo reboot.
linux will no restart.
The only way to get the board to work is to reimage the SD which of course deletes all the updates etc.
Cannot seam to get round this one.
Any ideas on this one.
Kind Regards
MikeD
#47
I have just re-imaged the SD again.
Gone through the update and install as directed.
To see if it solved the problem I did the following.
ctrl-alt-F1 to get back to a login prompt.
then staopped the lxdm service with
/etc/init.d/lxdm stop.
Then restarted with
/etc/init.d/lxdm start.
I then get my desktop with working mouse all looked OK so that is a fix.
However, my board then crashed and I am back to not being able to reboot it. Without re-imaging the SD
Wondering if I have a faulty board.
regards.
MikeD
#48
(07-08-2018, 01:54 PM)mikeD Wrote: I have just re-imaged the SD again.
Then restarted with
regards.
MikeD
Yep, fixed in newest image. Was a issue with resize_rootfs apparently. Now also mouse cursor works out of the box.
#49
0.7.4
looking really good now.
thanks
mikeD
#50
Thread closed and archived. New release from ayufan is 0.7.8. Discussion on 0.7.8 and future pre-releases here.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,646 09-27-2026, 11:42 AM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,153 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,449 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,806 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,885 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 2,930 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 18,376 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 3,083 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 11,833 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,390 07-24-2021, 09:46 PM
Last Post: Mentaluproar
