how to upgrade stock rom 8.1 on XZ file
Hi there,
I have dowload the 8.1 Oreo stock rom with file XZ. I don't know how to upgarde my Rock64 with this XZ file. Please tell me how to upgrade thid XZ file on my Rock64. Thanks
You cannot 'upgrade' your Rock64's android system. This will purge your installation and install the new A 8.1.
You need to unarchive the xz file so you get a .img file. All other information concerning flashing OS images can be found here: http://wiki.pine64.org/index.php/NOOB
(07-04-2018, 01:34 AM)Luke Wrote: You cannot 'upgrade' your Rock64's android system. This will purge your installation and install the new A 8.1.
Luke, I have unrar the XZ file and got img file, then upgrade by Android Tool V2.38. It showed "Loading firmware failed".
How can I do now?
Its not a file you can use with RK tools. You need Etcher similar dd utility. Read the link I posted for you.
(07-05-2018, 01:37 AM)Luke Wrote: Its not a file you can use with RK tools. You need Etcher similar dd utility. Read the link I posted for you.
Yeah I have to use Etcher 1.44
1. select Image: I choose stock rom 8.1.img
2. Select Drive: It said "connect a drive" but I cannot click on it, It doesn't happen.
Please tell me how to use Etcher 1.44.
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 3,303 09-09-2019, 09:39 AM
Last Post: shivarj89
  Enable I2C, I2s, SPI in boot-config file? HelgeMK 3 12,048 08-14-2018, 10:59 AM
Last Post: pas059
  New User - No image file in LibreELEC download Frogmella 9 16,884 06-11-2018, 01:01 PM
Last Post: Frogmella
  4GB version out of stock? christian_ 3 7,743 10-11-2017, 04:04 PM
Last Post: cbonniot
