Is PCIE x4 bootable for NVMe SSD under Linux
I am not sure uBoot will support NVMe SSD to boot off from PCIE x4 .
Anyone can test and tell me?
Really appreciated.
(05-21-2018, 09:01 AM)jzhang18 Wrote: I am not sure uBoot will support NVMe SSD to boot off from PCIE x4 .
Really appreciated.
I ordered an NVMe drive today. Once Linux images are out and we can flash uboot SPI I'll test.
Really appreciated.
If that is true,  it will be amazing for the performance!
Ayufan Image 0.6.52
rock64@rockpro64:~$ lspci 00:00.0 PCI bridge: Rockchip Inc. RK3399 PCI Express Root Port Device 0100 01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961
Disk /dev/nvme0n1: 232.9 GiB, 250059350016 bytes, 488397168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
rock64@rockpro64:/mnt$ sudo dd if=/dev/zero of=sd.img bs=1M count=4096 conv=fdatasync 4096+0 records in 4096+0 records out 4294967296 bytes (4.3 GB, 4.0 GiB) copied, 11.795 s, 364 MB/s
Only x2 atm. But it works Big Grin  Thanks Ayufan!!
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(06-10-2018, 02:19 PM)Bullet64 Wrote: Ayufan Image 0.6.52
Plug and play? Or did you need to configure anything? I'm still waiting on my M2/NVMe drive before I can try it out. Shouldn't be too long now. I'm not getting any activity from the SATA card, but the onboard power LED isn't lit so I suspect the regulator is not switched on for it.
Plug & Play  Big Grin But not stable atm.
When not allowed, please delete the link. More infos -> https://frank-mankel.org/topic/58/rockpro64-pcie-x4/7 (only german)
3. RockPro64 v2.1
(06-11-2018, 07:40 AM)Bullet64 Wrote: Plug & Play  Big Grin But not stable atm.
Thanks for the link... I'll be sure to follow your progress Wink I'm getting some PCI-e test cards so I can check the PCI-e ports, and can hopefully get the NVM card running once the drive arrives. I'm surprised that just plugging in the SATA card with no drives attached didn't work (get detected) for me though... although from your notes it seems like there is a fault? Since AFAIK this hasn't been documented as a possible known issue on the forum yet (as it should have been by now), I'm assuming from the #rock64 IRC chat history from the 27/28th of May 2018 that removal of the resistor indicated in this picture is the solution to my problem with a pre-production rockpro64? https://app.box.com/s/wghe5gu40dliaz2014g1rj28i2j164bv If so, looks easy enough, will warm up the soldering iron and do some surgery Smile
Yes, i have remove the resistor on preproduction rockpro64!!!! Please take care, that is not without danger!
My resistor has removed a specialist.
After this on NVMe Card the red LED is ON Smile And the NVMe card works.
On the SATA-Card is an white(?) LED. But this LED isn't ON. So maybe wrong pcie-regulator ???
rock64@rockpro64:~$ sudo dmesg | grep -E "pci" [    0.502571] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0) [    0.502619] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree [    0.502657] vcc3v3_pcie: supplied by dc_12v [    0.502723] vcc3v3_pcie: 3300 mV [    0.502878] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV [    0.906753] phy phy-pcie-phy.5: Looking up phy-supply from device tree [    0.906762] phy phy-pcie-phy.5: Looking up phy-supply property in node /pcie-phy failed [    0.908221] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep [    0.908231] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup [    0.908258] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0) [    0.908533] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree [    0.908622] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree [    0.908633] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed [    0.908646] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [    0.908671] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree [    0.908681] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed [    0.908692] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [    0.929331] rockchip-pcie f8000000.pcie: invalid power supply [    0.965700] PCI host bridge /pcie@f8000000 ranges: [    0.966078] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [    0.966105] pci_bus 0000:00: root bus resource [bus 00-1f] [    0.966128] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [    0.966152] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [    0.966211] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 [    0.966330] pci 0000:00:00.0: supports D1 [    0.966339] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [    0.966581] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [    0.966733] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-1f] (conflicts with (null) [bus 00-1f]) [    0.966767] pci 0000:01:00.0: [1b21:0612] type 00 class 0x010601 [    0.966810] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [    0.966834] pci 0000:01:00.0: reg 0x10: [io  size 0x0008] [    0.966850] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [    0.966871] pci 0000:01:00.0: reg 0x14: [io  size 0x0004] [    0.966887] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [    0.966908] pci 0000:01:00.0: reg 0x18: [io  size 0x0008] [    0.966923] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [    0.966945] pci 0000:01:00.0: reg 0x1c: [io  size 0x0004] [    0.966960] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [    0.966981] pci 0000:01:00.0: reg 0x20: [io  size 0x0020] [    0.966997] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff] [    0.967013] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] [    0.968329] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [    0.968363] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff] [    0.968392] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] [    0.968426] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa0101ff] [    0.968452] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0020] [    0.968474] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0020] [    0.968496] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0008] [    0.968517] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0008] [    0.968539] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0008] [    0.968560] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0008] [    0.968581] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0004] [    0.968602] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0004] [    0.968623] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0004] [    0.968644] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0004] [    0.968667] pci 0000:00:00.0: PCI bridge to [bus 01] [    0.968692] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff] [    0.968764] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [    0.969009] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [    0.969032] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [    0.969057] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded [    0.969161] aer 0000:00:00.0:pcie02: service driver aer loaded [    1.225528] ehci-pci: EHCI PCI platform driver
rock64@rockpro64:~$ lspci 00:00.0 PCI bridge: Rockchip Inc. RK3399 PCI Express Root Port Device 0100 01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
3. RockPro64 v2.1
Thanks for the effort you put in for posting this information (with nice photos too).
I doubt that the link will be removed. There is nothing better for sales than seeing real people buy and actually using products.
with 0.6.59
root@rockpro64:/home/rock64# lspci -vvv 00:00.0 PCI bridge: Rockchip Inc. RK3399 PCI Express Root Port Device 0100 (prog-if 00 [Normal decode]) Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort+ <MAbort+ >SERR+ <PERR+ INTx- Latency: 0 Interrupt: pin A routed to IRQ 236 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: 00000000-00000fff Memory behind bridge: fa000000-fa0fffff Prefetchable memory behind bridge: 00000000-000fffff Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR- BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B- PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn- Capabilities: [80] Power Management version 3 Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-) Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME+ Capabilities: [90] MSI: Enable+ Count=1/1 Maskable+ 64bit+ Address: 00000000fee30040  Data: 0000 Masking: 00000000  Pending: 00000000 Capabilities: [b0] MSI-X: Enable- Count=1 Masked- Vector table: BAR=0 offset=00000000 PBA: BAR=0 offset=00000008 Capabilities: [c0] Express (v2) Root Port (Slot+), MSI 00 DevCap: MaxPayload 256 bytes, PhantFunc 0 ExtTag- RBE+ DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+ RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ MaxPayload 128 bytes, MaxReadReq 512 bytes DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend- LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+ LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk- ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt+ LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt- SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise- Slot #0, PowerLimit 0.000W; Interlock- NoCompl- SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg- Control: AttnInd Off, PwrInd Off, Power+ Interlock- SltSta: Status: AttnBtn- PowerFlt- MRL+ CmdCplt- PresDet- Interlock- Changed: MRL- PresDet- LinkState- RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible- RootCap: CRSVisible- RootSta: PME ReqID 0000, PMEStatus- PMEPending- DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via message ARIFwd+ DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd- LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis- Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS- Compliance De-emphasis: -6dB LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1- EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest- Capabilities: [100 v2] Advanced Error Reporting UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol- CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr- CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+ AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn- Capabilities: [274 v1] Transaction Processing Hints Interrupt vector mode supported Device specific mode supported Steering table in TPH capability structure Kernel driver in use: pcieport 01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 (prog-if 02 [NVM Express]) Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 235 Region 0: Memory at fa000000 (64-bit, non-prefetchable) [size=16K] Capabilities: [40] Power Management version 3 Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-) Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME- Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+ Address: 0000000000000000  Data: 0000 Capabilities: [70] Express (v2) Endpoint, MSI 00 DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported- RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset- MaxPayload 128 bytes, MaxReadReq 512 bytes DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend- LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+ LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk- ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt- LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt- DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis- Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS- Compliance De-emphasis: -6dB LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1- EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest- Capabilities: [b0] MSI-X: Enable+ Count=8 Masked- Vector table: BAR=0 offset=00003000 PBA: BAR=0 offset=00002000 Capabilities: [100 v2] Advanced Error Reporting UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol- CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr- CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+ AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn- Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00 Capabilities: [158 v1] Power Budgeting <?> Capabilities: [168 v1] #19 Capabilities: [188 v1] Latency Tolerance Reporting Max snoop latency: 0ns Max no snoop latency: 0ns Capabilities: [190 v1] L1 PM Substates L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+  PortCommonModeRestoreTime=10us PortTPowerOnTime=10us L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-   T_CommonMode=0us LTR1.2_Threshold=0ns L1SubCtl2: T_PwrOn=10us Kernel driver in use: nvme
Yeah
iozone with Samsung 960 EVO m.2 256GB
root@rockpro64:/mnt# sudo iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O        Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins             Al Slater, Scott Rhine, Mike Wisner, Ken Goss             Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,             Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,             Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,             Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,             Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,             Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Wed Jul  4 03:21:54 2018 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size.                                                               random    random     bkwd    record    stride                                                   kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread           102400       4    69551   109290   128601   114462    25822    73054        102400      16   133640   240685   269449   273207   117705   192497        102400     512   582963   588868   458828   465076   417720   551456        102400    1024   519443   628637   490247   497807   468750   627362        102400   16384   977517  1048544  1032961  1097595  1070311  1094686
Thanks Ayufan!
3. RockPro64 v2.1
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,213 09-27-2026, 11:42 AM
  RK3399 PCIe enumeration jhadd 0 3,561 01-31-2024, 08:56 AM
Last Post: jhadd
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,372 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,724 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 8,012 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 7,388 10-14-2022, 06:24 AM
Last Post: rwk-
  RockPro64 linux console video mode callegar 0 3,008 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 18,684 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 12,089 01-03-2022, 10:32 AM
Last Post: whitecat23
  No PCIe controller detected... Limhes 1 3,972 11-23-2021, 06:23 AM
Last Post: Limhes
