[split] Buffer I/O and blk_update_request errors
I also have these error when transfer files with lastest image; 4.4.126-rockchip-ayufan-239
root@rock64:/home# uname -a Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 GNU/Linux
logs:
[ 7053.025619] xhci-hcd xhci-hcd.9.auto: xHCI host not responding to stop endpoint command. [ 7053.027925] xhci-hcd xhci-hcd.9.auto: Assuming host is dying, halting host. [ 7053.030144] xhci-hcd xhci-hcd.9.auto: xHCI host not responding to stop endpoint command. [ 7053.032564] xhci-hcd xhci-hcd.9.auto: Assuming host is dying, halting host. [ 7053.053523] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds. [ 7053.055966] xhci-hcd xhci-hcd.9.auto: Non-responsive xHCI host is not halting. [ 7053.058448] xhci-hcd xhci-hcd.9.auto: Completing active URBs anyway. [ 7053.060916] xhci-hcd xhci-hcd.9.auto: HC died; cleaning up [ 7053.060919] xhci-hcd xhci-hcd.9.auto: HC died; cleaning up [ 7053.061095] usb 4-1: USB disconnect, device number 2 [ 7053.062259] usb 5-1: USB disconnect, device number 2 [ 7053.062268] usb 5-1.2: USB disconnect, device number 3 [ 7053.078718] sd 0:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 [ 7053.081660] sd 0:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 01 e4 b0 e0 00 00 f0 00 [ 7053.084568] blk_update_request: I/O error, dev sdc, sector 31764704 [ 7053.087646] sd 0:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 [ 7053.090805] sd 0:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 01 e4 b1 d0 00 00 10 00 [ 7053.093960] blk_update_request: I/O error, dev sdc, sector 31764944 [ 7053.100791] sd 1:0:0:0: [sde] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.104289] sd 1:0:0:0: [sde] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 64 b9 78 00 00 00 08 00 00 [ 7053.107918] blk_update_request: I/O error, dev sde, sector 6601080 [ 7053.111398] Buffer I/O error on dev sde2, logical block 792111, lost async page write [ 7053.115886] sd 1:0:0:1: [sdf] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.119718] sd 1:0:0:1: [sdf] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 d5 8f 69 40 00 00 00 f0 00 00 [ 7053.123709] blk_update_request: I/O error, dev sdf, sector 3582945600 [ 7053.127593] Buffer I/O error on dev sdf2, logical block 447835176, lost async page write [ 7053.131756] Buffer I/O error on dev sdf2, logical block 447835177, lost async page write [ 7053.135878] Buffer I/O error on dev sdf2, logical block 447835178, lost async page write [ 7053.139995] Buffer I/O error on dev sdf2, logical block 447835179, lost async page write [ 7053.144136] Buffer I/O error on dev sdf2, logical block 447835180, lost async page write [ 7053.148259] Buffer I/O error on dev sdf2, logical block 447835181, lost async page write [ 7053.152371] Buffer I/O error on dev sdf2, logical block 447835182, lost async page write [ 7053.156497] Buffer I/O error on dev sdf2, logical block 447835183, lost async page write [ 7053.160601] Buffer I/O error on dev sdf2, logical block 447835184, lost async page write [ 7053.191852] sd 1:0:0:0: [sde] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.196059] sd 1:0:0:0: [sde] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 31 3f ad 78 00 00 00 08 00 00 [ 7053.200446] blk_update_request: I/O error, dev sde, sector 826256760 [ 7053.205062] sd 1:0:0:1: [sdf] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.209616] sd 1:0:0:1: [sdf] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 d5 8f 6a 30 00 00 00 f0 00 00 [ 7053.214281] blk_update_request: I/O error, dev sdf, sector 3582945840 [ 7053.245739] sd 1:0:0:0: [sde] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.250551] sd 1:0:0:0: [sde] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 38 99 5c f0 00 00 00 08 00 00 [ 7053.255530] blk_update_request: I/O error, dev sde, sector 949574896 [ 7053.260882] sd 1:0:0:1: [sdf] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.265991] sd 1:0:0:1: [sdf] tag#0 CDB: opcode=0x88 88 00 00 00 00 00 00 66 8a 48 00 00 00 f0 00 00 [ 7053.271249] blk_update_request: I/O error, dev sdf, sector 6720072 [ 7053.306838] sd 1:0:0:1: [sdf] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.312232] sd 1:0:0:1: [sdf] tag#0 CDB: opcode=0x88 88 00 00 00 00 00 00 66 8b 38 00 00 00 10 00 00 [ 7053.317787] blk_update_request: I/O error, dev sdf, sector 6720312 [ 7053.353772] sd 1:0:0:1: [sdf] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 [ 7053.359469] sd 1:0:0:1: [sdf] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 d5 8f 6b 20 00 00 00 f0 00 00 [ 7053.365308] blk_update_request: I/O error, dev sdf, sector 3582946080 [ 7053.644078] usb 5-1.3: USB disconnect, device number 4 [ 7054.427194] usb 5-1.4: USB disconnect, device number 5 [ 7054.444836] sd 2:0:0:0: [sdg] Synchronizing SCSI cache [ 7054.458807] sd 2:0:0:0: [sdg] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00 [ 7054.477506] sd 2:0:0:1: [sdh] Synchronizing SCSI cache [ 7054.483615] sd 2:0:0:1: [sdh] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00 [ 7084.935491] buffer_io_error: 2931 callbacks suppressed [ 7084.941556] Buffer I/O error on dev sdc1, logical block 4697368, async page read
and
[    4.396580] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff36000 failed [    4.610876] ttyS2 - failed to request DMA, use interrupt mode [ 7053.084568] blk_update_request: I/O error, dev sdc, sector 31764704 [ 7053.093960] blk_update_request: I/O error, dev sdc, sector 31764944 [ 7053.107918] blk_update_request: I/O error, dev sde, sector 6601080 [ 7053.111398] Buffer I/O error on dev sde2, logical block 792111, lost async page write [ 7053.123709] blk_update_request: I/O error, dev sdf, sector 3582945600 [ 7053.127593] Buffer I/O error on dev sdf2, logical block 447835176, lost async page write [ 7053.131756] Buffer I/O error on dev sdf2, logical block 447835177, lost async page write [ 7053.135878] Buffer I/O error on dev sdf2, logical block 447835178, lost async page write [ 7053.139995] Buffer I/O error on dev sdf2, logical block 447835179, lost async page write [ 7053.144136] Buffer I/O error on dev sdf2, logical block 447835180, lost async page write [ 7053.148259] Buffer I/O error on dev sdf2, logical block 447835181, lost async page write [ 7053.152371] Buffer I/O error on dev sdf2, logical block 447835182, lost async page write [ 7053.156497] Buffer I/O error on dev sdf2, logical block 447835183, lost async page write [ 7053.160601] Buffer I/O error on dev sdf2, logical block 447835184, lost async page write [ 7053.200446] blk_update_request: I/O error, dev sde, sector 826256760 [ 7053.214281] blk_update_request: I/O error, dev sdf, sector 3582945840 [ 7053.255530] blk_update_request: I/O error, dev sde, sector 949574896 [ 7053.271249] blk_update_request: I/O error, dev sdf, sector 6720072 [ 7053.317787] blk_update_request: I/O error, dev sdf, sector 6720312 [ 7053.365308] blk_update_request: I/O error, dev sdf, sector 3582946080 [ 7054.458807] sd 2:0:0:0: [sdg] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00 [ 7054.483615] sd 2:0:0:1: [sdh] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00 [ 7084.935491] buffer_io_error: 2931 callbacks suppressed [ 7084.941556] Buffer I/O error on dev sdc1, logical block 4697368, async page read [ 7210.978277] Buffer I/O error on dev sde2, logical block 118663838, async page read [ 7210.999790] Buffer I/O error on dev sde2, logical block 118663838, async page read [ 7255.266719] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.287599] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.296324] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.303723] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.310567] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.317369] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.324257] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.330882] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.423357] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.430015] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7261.765445] buffer_io_error: 51 callbacks suppressed [ 7261.771323] Buffer I/O error on dev sde2, logical block 45133896, async page read [ 7265.092062] Buffer I/O error on dev sde2, logical block 326498839, async page read root@rock64:/srv/dev-disk-by-label-KEV.60GB/tor_complete/tutorials# clear root@rock64:/srv/dev-disk-by-label-KEV.60GB/tor_complete/tutorials# dmesg | grep -i "error\|fail\|warn" [    0.545417] vcc_sd: regulator get failed, ret=-517 [    1.102677] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed [    1.103309] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed [    1.103773] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed [    1.103797] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator [    1.104972] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply property in node /usb3-phy@ff470000 failed [    1.104998] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator [    1.105559] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed [    1.106073] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed [    1.109008] phy phy-ff430000.hdmiphy.4: Looking up phy-supply property in node /hdmiphy@ff430000 failed [    1.112528] rk-vcodec vpu_combo: Looking up vcodec-supply property in node /vpu_combo failed [    1.112981] rk-vcodec vpu_combo: failed on clk_get clk_cabac [    1.113042] rk-vcodec vpu_combo: failed on clk_get clk_core [    1.118542] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff36000 failed [    1.253133] rockchip-vop ff370000.vop: failed to get vop lut registers [    1.254263] rockchip-vop ff370000.vop: failed to get vop cabc lut registers [    1.256460] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports [    1.262470] rockchip-drm display-subsystem: failed to parse display resources [    1.797563] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed [    1.798651] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed [    3.083282] dwmmc_rockchip ff520000.dwmmc: lookup for GPIO wp failed [    3.106760] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO cd failed [    3.106818] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO wp failed [    4.215149] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff36000 failed [    4.281407] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [    4.396580] rk-vcodec ff360000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff36000 failed [    4.610876] ttyS2 - failed to request DMA, use interrupt mode [ 7053.084568] blk_update_request: I/O error, dev sdc, sector 31764704 [ 7053.093960] blk_update_request: I/O error, dev sdc, sector 31764944 [ 7053.107918] blk_update_request: I/O error, dev sde, sector 6601080 [ 7053.111398] Buffer I/O error on dev sde2, logical block 792111, lost async page write [ 7053.123709] blk_update_request: I/O error, dev sdf, sector 3582945600 [ 7053.127593] Buffer I/O error on dev sdf2, logical block 447835176, lost async page write [ 7053.131756] Buffer I/O error on dev sdf2, logical block 447835177, lost async page write [ 7053.135878] Buffer I/O error on dev sdf2, logical block 447835178, lost async page write [ 7053.139995] Buffer I/O error on dev sdf2, logical block 447835179, lost async page write [ 7053.144136] Buffer I/O error on dev sdf2, logical block 447835180, lost async page write [ 7053.148259] Buffer I/O error on dev sdf2, logical block 447835181, lost async page write [ 7053.152371] Buffer I/O error on dev sdf2, logical block 447835182, lost async page write [ 7053.156497] Buffer I/O error on dev sdf2, logical block 447835183, lost async page write [ 7053.160601] Buffer I/O error on dev sdf2, logical block 447835184, lost async page write [ 7053.200446] blk_update_request: I/O error, dev sde, sector 826256760 [ 7053.214281] blk_update_request: I/O error, dev sdf, sector 3582945840 [ 7053.255530] blk_update_request: I/O error, dev sde, sector 949574896 [ 7053.271249] blk_update_request: I/O error, dev sdf, sector 6720072 [ 7053.317787] blk_update_request: I/O error, dev sdf, sector 6720312 [ 7053.365308] blk_update_request: I/O error, dev sdf, sector 3582946080 [ 7054.458807] sd 2:0:0:0: [sdg] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00 [ 7054.483615] sd 2:0:0:1: [sdh] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00 [ 7084.935491] buffer_io_error: 2931 callbacks suppressed [ 7084.941556] Buffer I/O error on dev sdc1, logical block 4697368, async page read [ 7210.978277] Buffer I/O error on dev sde2, logical block 118663838, async page read [ 7210.999790] Buffer I/O error on dev sde2, logical block 118663838, async page read [ 7255.266719] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.287599] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.296324] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.303723] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.310567] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.317369] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.324257] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.330882] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.423357] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7255.430015] Buffer I/O error on dev sde2, logical block 792111, async page read [ 7261.765445] buffer_io_error: 51 callbacks suppressed [ 7261.771323] Buffer I/O error on dev sde2, logical block 45133896, async page read [ 7265.092062] Buffer I/O error on dev sde2, logical block 326498839, async page read
What device are you booting from. Your boot device looks like its reporting sector errors. Is it SD, eMMC or USB.
(06-01-2018, 06:35 PM)Rocklobster Wrote: What device are you booting from. Your boot device looks like its reporting sector errors. Is it SD, eMMC or USB.
Boot from microSD, and yes, sector errors on external usb hard drive
(06-01-2018, 07:51 PM)i69fstop Wrote: Boot from microSD, and yes, sector errors on external usb hard drive
Split thread as is a different error.
You may want to resolve the sector errors on the external drive first. Make sure there isn't anything wrong with the file system, and then if you have a powered USB hub, try connecting it to the rock64 in case it isn't being given enough power.
@pfeerick,
My hard disk connect to 12v HD docking station, I wouldn't need a powered usb hub right?
(06-02-2018, 11:34 AM)i69fstop Wrote: My hard disk connect to 12v HD docking station, I wouldn't need a powered usb hub right?
Yeah, that pretty much rules out the need for one if it's a self-powered drive. Drats!
  i2c0 transfers cause bus errors michaelanburaj 0 3,049 07-14-2020, 02:25 PM
Last Post: michaelanburaj
  Errors were encountered while processing: initramfs-tools MotoTom 0 3,808 03-03-2019, 11:53 AM
Last Post: MotoTom
  Freeze/reboot/errors when compiling - unable to make - reproducible and not isolated jovval 2 6,811 10-02-2018, 08:10 AM
Last Post: jovval
  USB Errors with ASI camera GuLinux 0 3,121 09-18-2018, 03:48 AM
Last Post: GuLinux
  weird errors on boot Mentaluproar 9 18,697 03-24-2018, 05:48 AM
Last Post: pfeerick
  bionic upgrade errors 6.25 193 noob 0 3,324 03-17-2018, 01:35 PM
Last Post: noob
