Remix OS
#21
I went ahead and downloaded the image from google drive and attached it to the torrent. This helped and allowed the image to be shared with other users.
(03-17-2016, 07:52 AM)KryPtAlIvIaN Wrote: TL, could we get you to attach some public trackers to the remix os and arch linux builds. Current state wont allow you to download via bit torrent.
I will check with KH Goh on your request.
I made some change on the torrent. If possible, re-download the .torrent file from our wiki and try again. Please let me know if still got problem.
Regards,
KH Goh
Is there anyway to remote desktop into Remix OS? I have it running on my Pine but it is hard to use because of the overscan problem I was hoping to remote into the Pine so I could see the whole desktop and play with it. Thanks for any help
You can try out TeamViewer (without root) or VNCserver + VNCviewer (with root).
My forum topics:
• Create a WiFi hotspot on Debian 8
• Turn your Pine64 into a music server with mpd
• Adjust brightness of LCD on Armbian Desktop with 1 click
• My cases for Pine64 (acryl, lego & wood)
• Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
I have installed RemixOS on my freshly received PINE64+ 1Gb and have some troubles: it keep on rebooting; it starts fine but crashes as soon as I move the mouse or click on Chrome.
(I changed the OS and keyboard input language to French)
Any thoughts?
(03-21-2016, 03:34 AM)antx0n Wrote: Hi,
Any thoughts?
If keep rebooting, this means the Pine A64 board doesn't getting stable power source. Please check on your power adapter, make sure is +5V 2A type and also the USB cable quality.
I had no problems with Remix rebooting. It works smoother than the Android image shipped in BSP.
Only downside with Remix so far is lack of Google app store (I tried installing it last night but it hangs...)
as for the cables I would go with: http://www.amazon.com/gp/product/B018IAXSS4.
Look at AWG rating - the lower the better - 20 for Tronsmart cables,
28 for Amazon Basics cable - sadly I was expecting better quality from AMZ...
(03-21-2016, 08:50 AM)janjwerner Wrote: I had no problems with Remix rebooting. It works smoother than the Android image shipped in BSP.
We custom made a power only USB cable (means no data lines) for backerkit folks, such cable normally does good job on supply power.
For Amazon, I may try out such cable: http://www.amazon.com/PortaPow-Specialis...+usb+cable
On the Google store app, I also notice lacking on the beta build, will check with Remix folks whether able to add in. I will meet up with them at Beijing on early April. If there is any suggestion about Remix OS beta build, please post here. I will collect and feedback.
TL LIm, I got in touch with the guys of Remix and they told that 2GB RAM is a minimum requirement for the OS to run smoothly. Personally, I wouldn't mind as my boards will come with 2GB but what about those with 1GB boards?
  sourround sound - Remix MrSarkasmus 0 5,286 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 65,007 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 7,192 07-14-2018, 11:48 AM
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,711 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,494 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,870 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 34,162 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,647 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,768 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
  No microphone input in Remix xtcrefugee 3 15,283 08-19-2016, 06:24 PM
Last Post: jkmooney
