Boots, but won't recognize keyboard
I have one of the original Pine64 boards that works perfectly -- even with this keyboard, just as background.
I just received 2 brand new Pine-64 LTS boards and have 2 problems:
1) Can't boot the same image as the older board and I can't find a way to 'convert' the image to be able to use it. So I burned a new card.
2) New card boots just fine. I get a 'pine64so login: ' prompt. But it does not recognize the keyboard input.
It's admittedly a Mac Keyboard, but the same keyboard works with the older Pine64.
It's currently booted via battery since I didn't realize there was no more USB power in, and I neglected to order the 5v power supplies.
Thanks!
dg
Mac keyboards need a special driver to work on Linux, which image/kernel are you using at the moment?
Actually, I dug up a generic keyboard, which doesn’t work either. It seems that the usb interface is dead on this board.
Which image are you using?
Solved. There was a loose solder joint on the USB hub connecting to the board.
  Keyboard layout dealie 0 2,915 08-27-2021, 12:55 PM
Last Post: dealie
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 8,082 07-14-2021, 02:49 PM
  First time user experiencing weird keyboard issues kendew 5 10,948 06-19-2021, 08:14 AM
Last Post: rotwang
  Pinebook Pro- configuration aborts setting keyboard layout scroall 10 20,985 10-30-2020, 11:58 AM
Last Post: scroall
  Pinebook 11" keyboard cvmiller 2 6,400 11-13-2018, 06:01 PM
Last Post: cvmiller
  Boots just fine. Can not install new image. willpine 5 12,067 07-25-2017, 06:39 AM
Last Post: willpine
  Android never fully boots. gpoints 6 12,714 04-13-2016, 09:16 AM
Last Post: Tarjei85
