RTL8192EU WIFI
I've got TP-Link TL-WN823N usb wifi dongle based on RTL8192EU chip and it does not work in Linux loaded to ROCK64 eMMC
Does anyone know how to get this usb dongle working?
(02-26-2018, 07:16 AM)elik745i Wrote: I've got TP-Link TL-WN823N usb wifi dongle based on RTL8192EU chip and it does not work in Linux loaded to ROCK64 eMMC
I'm not familiar with this wifi device, but I'll try and help you if I can. What image/OS are you trying to get it working on?
Thank you so much in advance, I'm using Xenial Mate: xenial-mate-rock64-0.5.15-136-arm64.img.xz
https://github.com/ayufan-rock64/linux-b...tag/0.5.15
(02-27-2018, 05:30 AM)elik745i Wrote: Thank you so much in advance, I'm using Xenial Mate: xenial-mate-rock64-0.5.15-136-arm64.img.xz
if you type "lsusb -t" does it show the device?
rock64@rock64:~$ lsusb -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    |__ Port 1: Dev 4, If 0, Class=Hub, Driver=hub/4p, 12M
        |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 12M
        |__ Port 2: Dev 6, If 0, Class=Wireless, Driver=btusb, 12M
        |__ Port 2: Dev 6, If 1, Class=Wireless, Driver=btusb, 12M
        |__ Port 2: Dev 6, If 2, Class=Vendor Specific Class, Driver=, 12M
        |__ Port 2: Dev 6, If 3, Class=Application Specific Interface, Driver=, 12M
        |__ Port 3: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 4: Dev 8, If 0, Class=Mass Storage, Driver=usb-storage, 12M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
(02-27-2018, 08:55 AM)elik745i Wrote: rock64@rock64:~$ lsusb -t
Ok I found some drivers for it on github and built a dkms package from it, I have no idea if it will work or not as I don't have a dongle to try it on.
wget https://files.evilbunny.org/rtl8192eu-dk...-1_all.deb
sudo dpkg -i rtl8192eu-dkms_4.4.1-1_all.deb
Let me know how it goes.
terminal says:
dpkg: error: dpkg status database is locked by another process
after restart:
rock64@rock64:~$ wget https://files.evilbunny.org/rtl8192eu-dk...2018-02-28 15:04:31-- https://files.evilbunny.org/rtl8192eu-dk...-1_all.deb
Resolving files.evilbunny.org (files.evilbunny.org)... 139.99.156.27, 2402:1f00:8100:400::37
Connecting to files.evilbunny.org (files.evilbunny.org)|139.99.156.27|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1365150 (1.3M) [application/vnd.debian.binary-package]
Saving to: ‘rtl8192eu-dkms_4.4.1-1_all.deb.1’
rtl8192eu-dkms_4.4. 100%[===================>] 1.30M 224KB/s in 5.9s
2018-02-28 15:04:39 (224 KB/s) - ‘rtl8192eu-dkms_4.4.1-1_all.deb.1’ saved [1365150/1365150]
rock64@rock64:~$ sudo dpkg -i rtl8192eu-dkms_4.4.1-1_all.deb
Selecting previously unselected package rtl8192eu-dkms.
(Reading database ... 179632 files and directories currently installed.)
Preparing to unpack rtl8192eu-dkms_4.4.1-1_all.deb ...
Unpacking rtl8192eu-dkms (4.4.1-1) ...
dpkg: dependency problems prevent configuration of rtl8192eu-dkms:
rtl8192eu-dkms depends on dkms (>= 2.1.0.0); however:
Package dkms is not installed.
dpkg: error processing package rtl8192eu-dkms (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
rtl8192eu-dkms
I've managed to install it through explorer, simply clicking on deb file and installing through GUI. After restart it seems like it's working! Thank you so much!
Could you please explain how did you compile the file so I do not bother you again in the future?
Again big thanks for your support!
(02-28-2018, 11:09 AM)elik745i Wrote: I've managed to install it through explorer, simply clicking on deb file and installing through GUI. After restart it seems like it's working! Thank you so much!
The source code is extracted from the deb file and placed into /usr/src/rtl8192eu-4.4.1 and every time the kernel changes it will rebuild the module from source.
  get wifi mt7601u mediatek usb dongle to work Johannes 0 6,354 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 17,044 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  low speed wifi pas059 4 9,011 05-13-2019, 12:09 PM
Last Post: pas059
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 6,762 03-08-2019, 02:44 AM
Last Post: shripal17
  50 kb with RTL8188eu WIFI adapter Juice4 2 6,129 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 4,705 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 26,970 05-30-2018, 12:20 AM
Last Post: scalextrix
  Very disappointed with ROCK64 USB WIFI 802.11B/G/N Danielsan 0 3,515 04-23-2018, 09:51 AM
Last Post: Danielsan
  None of my Wifi modules work NicoD 7 14,610 04-05-2018, 02:53 PM
  Yet another thread on ROCK64 Wifi Adapter Woes zendrummer74 1 5,699 02-01-2018, 11:10 PM
Last Post: a1w.ca
