eMMC not recognized
I Bought 64GB eMMC and USB ADAPTER FOR EMMC MODULE from pine64 and nothing happens when I connect it to computer, if I connect only the reader without eMMC then a light is turned on and computer detects the device.
Tested on diferents computers.
Can the memory be broken or maybe I'm doing something wrong?
Thank you.
What OS are you using ?
(01-16-2018, 03:54 AM)Luke Wrote: What OS are you using ?
I have tried with Windows 10, 7, XP and Lubuntu on diferents computers.
1) connect the adaptor with eMMC to Ubuntu (I assume desktop). Does it show up in Disks utility or when you do?:
sudo fdisk -l
2) If the above doesn't work, please follow the instructions here and see what you get when you do
rkflashtool n
(01-16-2018, 07:33 AM)Luke Wrote: 1) connect the adaptor with eMMC to Ubuntu (I assume desktop). Does it show up in Disks utility or when you do?:
sudo fdisk -l
rkflashtool n
1) It doesn't show up with eMMC placed. If I connect the adaptor without eMMC then show up as "SD card reader".
2) I need to adquire a USB A-A cable, I'll try when I have it.
Also try a Android microSD to eMMC image from here, but screen remains black after "Rock 64" initial message.
Thank you for your help Smile
What about ?
sudo fdisk -l
Also, it can take a long time for Android to boot the first time from a SD card.
(01-17-2018, 03:56 AM)Luke Wrote: What about ?
sudo fdisk -l
Disk /dev/sda: 232,9 GiB, 250059350016 bytes, 488397168 sectors
Disklabel type: dos
Disk identifier: 0xb2396089
Disposit.  Inicio Start     Final  Sectores   Size Id Tipo
/dev/sda1  *       2048 488396799 488394752 232,9G 83 Linux
Only shows computer HD.
Wait several minutes for Android, maybe not enough. SD card become unusable after some attempts.
Thank you.
sudo fdisk -l
Disklabel type: dos
Thank you.
Which Android build ?
(01-17-2018, 06:29 AM)cfdiaz Wrote: Android 7.1.2 Stock Image [microSD to eMMC] [Rooted] [20171204]
Hmmm, perhaps you could join the IRC and have someone help you troubleshoot further and determine if its a fault with the eMMC itself.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,560 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 6,790 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,089 08-19-2021, 06:46 PM
Last Post: bcnaz
  Receiving errors about eMMC (?) acasta 11 26,803 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 48,066 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 175,016 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 3,786 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 6,177 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 14,864 05-06-2018, 05:41 PM
Last Post: pfeerick
  [SOLVED] stuck at emmc dr_dre 10 22,611 04-29-2018, 05:10 PM
Last Post: pfeerick
