What are these pins on PIN board?
On page of PINE A54-LTS https://www.pine64.org/?product=pine-a64-lts I see only photos of the board, no any technical specs. For example, can I know what all these pins and sockets do? What can I connect to it?
The answer to all your questions can be found in the wiki
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,419 10-06-2022, 08:46 PM
Last Post: ihab
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 26,659 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 10,961 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 6,879 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 5,898 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 3,787 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 11,874 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What is on the Micro SC card that came with the board? clawinus 1 6,171 11-03-2016, 02:33 PM
Last Post: MarkHaysHarris777
  Power Switch for Pine64 512MB Board MonarchOfLight 0 4,110 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  PineA64 512 reboot - board shut down indrajith 7 19,097 07-28-2016, 02:07 PM
Last Post: Ghost
