Android Images (ROCK64)
(10-29-2017, 03:25 PM)Luke Wrote: dkryder, I am using a regular remote with this build. Perhaps mouse/ keyboard behaves differently ?
It does. With a mouse and keyboard, a single click highlights the app and another click is needed to open the app. Redundant.
I also replaced the launcher and I wanted to get rid of some system apps, so I installed SuperSU and updated it just fine. Rebooted fine. Installed a root verifier and never was promoted by SuperSU to grant root permissions so verification failed. Same happens with Titanium Backup. Got frustrated and started a new project. Will probably come back to it very soon. I really want RKMC gone (outdated and entirely too many add-ons devoted to piracy.)
Yes, RKMC in its current form (with Exodus etc.) ought to be removed.
Anyone else having issues with the "Stock Build Android 7.1.2 Rooted [microSD Boot] [20171012] Release version"? Mine hangs quite a bit. Always getting errors stating that the current app is not responding. I can click wait and the app will eventually start responding.
(10-30-2017, 02:40 PM)medc69 Wrote: Anyone else having issues with the "Stock Build Android 7.1.2 Rooted [microSD Boot] [20171012] Release version"? Mine hangs quite a bit. Always getting errors stating that the current app is not responding. I can click wait and the app will eventually start responding.
yes, i get that also. if you click close app it will close and most times immediately restart it. as i continue to use it i get fewer of the errors. when i first started using the terminal app "termux" it would error almost every time i used it. now i can open it, use it for 30 min and close without any errors.i have no idea why. the rock64 is the first device to give me any issues with termux so i have to think it was some issue specific to rock64, maybe memory management.
Updated Android 7.1.2 Stock Image [microSD to eMMC] [Rooted] [20171204]
Updated Android 7.1.2 Stock Image [eMMC Boot] [Rooted] [20171204]
Updated Android 7.1.2 Stock Image [microSD Boot] [Rooted] [20171204]
Anything new of interest in those builds pineadmin ?
Sure is Luke. This build fixed my USB 3 issue! Thanks a million, pineadmin!
I have ROCK64/4GB/32GBemmc and i have problem with latest image from ayufan
android-7.1-rock-64-rock64_regular-v0.3.13-r115-update.zip
from this site https://github.com/ayufan-rock64/android-7.1/releases.
I write this image to emmc through USB A-A cable from Win7x64/AndroidTool with success after check image.
But after one hour with greyed logo "android" in middle of screen nothing more can do with keyboard or mouse?
On the other side with your image after 5minutes welcome screen with buttons appear and everything works.
Anybody try ayufan images or is there any hardware restriction with this images like monitor or must have touchscreen ?
Can you help me please where can i address question about this problem?
(01-05-2018, 12:45 PM)quantik Wrote: I have ROCK64/4GB/32GBemmc and i have problem with latest image from ayufan
Is that a development build?  Try android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz .
If that works for you, please let me know if you can find and install Chrome.
yes i was traying this AndroidTV link android-7.1-rock-64-rock64_atv-v0.3.13-r115-update.zip
and this one is working. After less then ten minutes i've heard in connected headphones welcome song on android
and welcome screen appears too.
The same welcome song  i have heard with regular android image too but nothing welcome screen appear after hour
only android starting logo.
and for toby
yes at last i found Chrome on all checked images from this forum range, you dont need to install him.
  rock64-android10-tv patchset for Firely AlexS 1 439 09-08-2026, 10:49 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,175 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,461 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,610 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,702 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,402 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,574 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,188 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,501 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,867 09-18-2020, 07:58 PM
Last Post: BowerR64
