Cant make WiFi working on ROCK64.
Hi People!
I have 2 usb dongles for WiFi, but none of them are working in Rock64.
First one is a TP-Link WN721N uses AR9271 chip and is not accepted.
The second is a DLink DWA-123 uses RTL8188EU driver and is not accepted.
I think this is the same used in the dongle sold originaly by Pine site.
I running a Rock64 board with 2 Rb of Ram.
S.O. = MATE 1.12.1
Release 16.04.3 LTS (Xenial Xerus) 64-bit
Kernel Linux 4.4.77-rockchip-ayufan-136 aarch64
Running ifconfig only lo and eth0 are shown.
Running iwconfig only lo and eth0 are shown.
With tplink atached:
rock64@rock64:~$ lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0cf3:9271 Atheros Communications, Inc. AR9271 802.11n
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
rock64@rock64:~$
With D-Link atached to USB 2.0:
Bus 003 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 003: ID 2001:3310 D-Link Corp.
My system is updated.
rock64@rock64:~$ sudo apt update
[sudo] password for rock64:
Hit:1 http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu xenial InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports xenial InRelease
Get:3 http://ports.ubuntu.com/ubuntu-ports xenial-security InRelease [102 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports xenial-updates InRelease [102 kB]
Get:5 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1,245 B]
Fetched 206 kB in 3s (52.3 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
rock64@rock64:~$
dmesg for DLink:
[ 2356.031492] usb 1-1: new high-speed USB device number 3 using dwc2
[ 2356.494490] usb 1-1: New USB device found, idVendor=2001, idProduct=3310
[ 2356.494522] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2356.494543] usb 1-1: Product: DWA-123 11n Adapter
[ 2356.494563] usb 1-1: Manufacturer: Realtek
[ 2356.494582] usb 1-1: SerialNumber: C0A0BB58700D
More information:
zgrep -i rtl /proc/config.gz
CONFIG_BT_RTL=y
CONFIG_BT_HCIBTUSB_RTL=y
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=m
# CONFIG_RTL8180 is not set
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL_CARDS=y
# CONFIG_RTL8192CE is not set
# CONFIG_RTL8192SE is not set
# CONFIG_RTL8192DE is not set
# CONFIG_RTL8723AE is not set
# CONFIG_RTL8723BE is not set
# CONFIG_RTL8188EE is not set
# CONFIG_RTL8192EE is not set
# CONFIG_RTL8821AE is not set
CONFIG_RTL8192CU=m
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
CONFIG_RTLWIFI_DEBUG=y
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8XXXU=m
CONFIG_RTL8XXXU_UNTESTED=y
# CONFIG_RTL_WIRELESS_SOLUTION is not set
CONFIG_RTL8188EU=m
CONFIG_RTL8188FU=m
# CONFIG_RTL8189ES is not set
# CONFIG_RTL8189FS is not set
# CONFIG_RTL8723BS is not set
# CONFIG_RTL8723CS is not set
# CONFIG_RTL8723DS is not set
# CONFIG_RTL8822BE is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_RTL2832_SDR=m
# CONFIG_RTL8192U is not set
# CONFIG_RTLLIB is not set
rock64@rock64:~$
modprobe rtl8188eu
modprobe: FATAL: Module rtl8188eu not found in directory /lib/modules/4.4.77-rockchip-ayufan-136
Well, what can I do for WiFi to work???
Download something, compile something???
Thanks in advance,
VieiraBrazil
Did you tried "modprobe r8188eu" or "modprobe 8188eu" instead ?
To figure out the filename, do a ' find /lib/modules -name "*8188*ko" ' ...
(10-22-2017, 07:41 AM)martinayotte Wrote: Did you tried "modprobe r8188eu" or "modprobe 8188eu" instead ?
Thanks for your reply.
This is the output:
rock64@rock64:~$ modprobe r8188eu
modprobe: FATAL: Module r8188eu not found in directory /lib/modules/4.4.77-rockchip-ayufan-136
rock64@rock64:~$ modprobe 8188eu
modprobe: ERROR: could not insert '8188eu': Operation not permitted
rock64@rock64:~$ sudo modprobe 8188eu
rock64@rock64:~$
rock64@rock64:~$ find /lib/modules -name "*8188*ko"
/lib/modules/4.4.77-rockchip-ayufan-136/kernel/drivers/net/wireless/rockchip_wlan/rtl8188fu/8188fu.ko
/lib/modules/4.4.77-rockchip-ayufan-136/kernel/drivers/net/wireless/rockchip_wlan/rtl8188eu/8188eu.ko
But I dont know what to do with this info.
what's next, man?
Vieirabrazil
(10-22-2017, 11:42 AM)vieirabrazil Wrote: rock64@rock64:~$ modprobe 8188eu
rock64@rock64:~$
So, you've figured out that "sudo" was required ... Tongue
Now, since driver is loaded, you should see the "wlan0" while doing "ifconfig",  right ?
Then, you can use "nmtui" to connect to your router AP...
rock64@rock64:~$
Hi martinayotte,
Thanks again.
Unfortunately, things are not as simple as they should be.
Take a look:
rock64@rock64:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 2a:09:b9:e3:f3:0c
          inet addr:10.1.1.111  Bcast:10.1.1.255  Mask:255.255.255.0
          inet6 addr: fe80::e2c0:5325:b971:bc55/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1778 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1133 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:346175 (346.1 KB)  TX bytes:352764 (352.7 KB)
          Interrupt:39
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:3 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:147 (147.0 B)  TX bytes:147 (147.0 B)
rock64@rock64:~$ iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
wlan0 or whatever was not recognized.
If you or someone else have another idea I would like very much to know.
Thanks,
New info from dmesg:
[   97.902876] =======================================================
[   97.902881] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[   97.902885] =======================================================
[   97.902890] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[   97.902896] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   97.902901] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[   97.902905] RTL871X: module init start
[   97.902911] RTL871X: rtl8188eu v4.3.24_16705.20160509
[   97.904423] usbcore: registered new interface driver rtl8188eu
[   97.904435] RTL871X: module init ret=0
wifi_power?
On my side, I'm running Armbian build which still use Ayufan's github source tree, and I've "wlan0" working properly ...
(10-23-2017, 12:25 PM)vieirabrazil Wrote: New info from dmesg:
wifi_power?
Hi vieirabrazil, did you find a solution to this? Im in the exact same position!
Hi Man,
No, same situation until now.
But like martinayotte said, in Armbian works ok. But the time I used it was command Line only.
I became disappointed with the level of development for ROCK64. I was expecting a true alternative to Raspberry Pi 3 to run Mate or some other flavor, without "stall" using Gmail / Youtube.
Since that sad experience Rock64 is in the shelf. I dont know the status now.
Good luck,
  DeskPi case alternative for ROCK64 v1k699 2 13,329 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,637 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,542 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 48,922 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,411 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,993 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,755 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,676 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,037 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 8,002 06-08-2022, 12:44 AM
Last Post: Zoz
