Is Plex on any of the images?
I've seen mention that some have run Plex, but I can't figure out which image they are referring to.  Is it available?
No, you have to install it yourself. Only Kodi is available, but i wouldn't recommend it right now.. If you install plex, leave feedback.
Trimis de pe al meu Nexus 6 folosind Tapatalk
I got the plex from this version. The "64-99".
https://github.com/ayufan-rock64/android.../tag/0.3.6
(10-03-2017, 11:38 AM)skyway Wrote: No, you have to install it yourself. Only Kodi is available, but i wouldn't recommend it right now.. If you install plex, leave feedback.
Leaving feedback of my experience.  I tried several different OS images before I finally got one to work with Plex, but it turned out to be actually very easy once I used the right image.  I flashed the latest Artful armhf test build by Auyfan, then just apt-get update, apt-get install plexmediaserver-installer, and it worked flawlessly.  In a web browser, open https://[rock64_ip_address]:32400/manage to access the web interface.  I also needed to apt-get install ntfs-3g to mount my ntfs hard drive as writable.
I was also able to install Oracle Java 8 from the existing repos and openhab using the Ubuntu instructions on the openhab website.
The best is to use `openmediavault/armhf`. It has Plex easy to install via Web panel.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(10-16-2017, 03:32 AM)ayufan Wrote: The best is to use `openmediavault/armhf`. It has Plex easy to install via Web panel.
I've installed OMV then enabled OMV-Extras For Plex repo then i tried installing the Plex Plugin but i get this
The following packages have unmet dependencies:
openmediavault-plexmediaserver : Depends: plexmediaserver but it is not installable or
                                          plexmediaserver-installer but it is not installable
E: Unable to correct problems, you have held broken packages.
I've figured it out i didn't need to enable the repo and i tried it worked!
  Rock64-4gb,Armbian Debian Stretch: Plex, Radarr, NZBGet and Sickchill WOW Baracuda2 1 4,895 02-27-2019, 03:34 PM
Last Post: Luke
  Archive of past Rock64 Linux Images? wbecks 3 6,381 01-03-2018, 05:24 PM
Last Post: dkryder
