How to manage Wifi in xenial-i3 i3wm image UPDATE
Information
Greetings,
I ran into a small glitch while trying to manage wifi connection on my new xenial image using the i3wm  tiling window manager;  my ubuntu-mate image connected fine ( same hardware ) but I could not get the connection to work using the cli wpa_supplicant that I am used to.
The solution is really simple , as it turns out;  use the cli version of Network-Manager !
First, I reinstalled Network-Manager;  you may not need to do this step :
       sudo apt isntall network-manager --reinstall
Then bring up the wlan0 interface :
       sudo ip link set wlan0 up      (optional)
and lastly start the connection with the nmcli tool :
       nmcli d wifi connect <ssid> password <passphrase>
That's it.
Shy
use these commands to monitor the connections:
       nmcli -p d
       nmcli -p c
Notes:
       nmcli d wifi
The above command is similar to scanning; will show the available SSID in the area.
Once a connection is established the connection is persistent;  when you reboot the system it will attempt to establish that same connection again;  similar to the gui nm.
nmtui also worked well for me if you want something terminal based but more friendly - its more gui-like than cli-like.
I didn't have to install anything - it seemed to be included with my system which was i3 installed on the stock Mate image.
Andy
(09-01-2017, 02:49 PM)AndyK Wrote: nmtui also worked well for me if you want something terminal based but more friendly - its more gui-like than cli-like.
thanks AndyK !
... ncurses based looks like;  its on my system and I tried it out;  thanks a lot/
Shy
I installed the mate-terminal ( i3wm standard terminal and font are just too small for my eyes ).
... anyway,  the  nmtui  looks much better on the mate-terminal ( when using a larger font ) using a full sized window for the terminal IMHO.
... especially when editing connections !
Wink
i think tui is the word you're looking for ;-)
Quote:I didn't have to install anything - it seemed to be included with my system which was i3 installed on the stock Mate image.
nmtui belongs to networkmanager, as the name suggests.
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,860 01-04-2022, 09:22 PM
Last Post: irongarment
  Wifi doesn't work correctly Fredric92 1 8,368 08-10-2021, 08:39 AM
Last Post: Jean-Marc LACROIX
Question Ran apt update on my Pinebook.. ford442 0 6,249 12-25-2020, 04:40 PM
Last Post: ford442
  Flakey WIFI (problems authenticating, etc.) robbiemacg 6 14,855 12-15-2019, 04:31 AM
Last Post: matze79
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 14,491 08-14-2019, 04:27 AM
Last Post: matze79
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 177,857 07-17-2019, 01:22 PM
Last Post: catsmile
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,586 06-11-2019, 01:36 PM
Last Post: k_mp
  Wifi I/F on Pinebook 11.6" eblot 2 7,057 05-19-2019, 04:53 PM
Last Post: Shoananas
  KDE Neon Pinebook remix edition RC image bshah 66 181,461 05-18-2019, 11:44 AM
Last Post: rookieone
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 24,796 05-01-2019, 12:09 PM
Last Post: frank-zappa
