Bliss OS for Pinebook
We really should move the discussion to a dedicated Bliss thread...
Anyways, two questions: 1) does suspend working reliably ? 2) Do you have an estimated ETA ?
(08-28-2017, 04:22 PM)Luke Wrote: We really should move the discussion to a dedicated Bliss thread...
seems to be mostly reliable, sleeps with power button, and lid close, and wakes with keypress or lid open. i did notice a couple wake events that don't allow it to fall back to sleep, so those still have a little work to be done there.
As for an ETA? Soon
Moved over the discussion to this thread and stickied.
(08-28-2017, 01:41 PM)electrikjesus Wrote: OK, brought in all the vendor changes for Bliss, so we now have wallpaper, freeform enabled by default,  working Taskbar, etc. Root needs a couple of commits reverted and a couple more added for it to work right. All the other options and toggles from Bliss-x86 project are there though Smile
Here's a video runthrough!! https://youtu.be/DPsbtQBILe8
Is it running off of SD or eMMC in this video ?
(08-30-2017, 04:25 AM)Luke Wrote: Moved over the discussion to this thread and stickied.
So far, I have only been testing the builds running off a 4 yr. old 8gb SDcard, I figured that would give me the best user case scenario.
lol, best user case scenario Wink alright, well, it would be worth trying running it off of eMMC storage - as that will greatly increase performance.
Is it worth it to make Bliss OS main eMMC OS now or it is better to wait few updates?
[Image: qGAeJ3y.png]
[Image: nzsZTTY.png]
Team Bliss is pleased to present to you
Bliss 7.3 - Pinebook
Although it might not act like it, this should be considered a beta build.
!!You are responsible for your own choices from this point forward. Please read the instructions and understand them before continuing!!
SDCard Install Instructions:
  • Insert your Pinebook SD card into your PC
  • Download the latest img.gz file from https://downloads.blissroms.com/Bliss/Official/pinebook/  from your linux or windows PC.
  • Then, using the Pinebook Installer, select Image, then browse to the downloaded img.gz file, and select that.
  • Select the proper SDcard location, followed by the Flash button. Then wait for it to flash and validate.
  • Finally, insert the SDcard back into the pinebook, and power on. You should see a Pinebook boot logo, followed by a few seconds of black screen leading into the boot animation.
EMMC Install Instructions: (adapted from here: https://forum.pine64.org/showthread.php?tid=4701 )
  • Download and flash the ubuntu EMMC install image to SD
  • Mount rootfs of the installer and delete the pinebook.img found in the installer
  • Rename Bliss image to 'pinbook.img' and copy the renamed image to the installers rootfs
  • put the SD into your Pinebook and boot into the installer
Confirmed Working:
  • Wifi
  • BT
  • Keyboard
  • Touchpad
  • video playback
  • Substratum
  • Root
  • Bunches of other stuff .
Not Working:
  • SuperSU will update, but not boot afterwards, so just don’t update.
  • HDMI extended displays will not work as it does in linux or windows, this is a current Android limitation. Mirror display using HDMI works well
  • Whatever I missed in my testing
Setup Instructions:
  • After the bootanimation completes, you will see a Android Starting progress bar on the screen. For speed sake, let’s wait till that finishes doing it’s thing. Then swipe down from the top, and select WiFi, and connect to your network.
  • Next, swipe down from the top status bar again, and you should see a dialog asking to setup a backup account. Select that, and sign into your Google account.
  • Finally, hit the Home button, and select your launcher (Select Google Now launcher for the traditional Android UI, or select Taskbar for the more desktop like, Freeform Windows based UI)
SOURCE: https://github.com/blissroms-pine64/platform_manifest
Credits: Ayufan and others for their wonderful work on Android 7.1 for PINE64, plus all the members of Team Bliss.
If you'd like to check out more of our work, please visit http://blissroms.com
This is fantastic!  Thanks for all the hard work that went into this!
#19
Is it possible to compile it? Smile
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#20
(08-31-2017, 01:16 AM)ayufan Wrote: Is it possible to compile it? Smile
Oops, I forgot to leave the source link. Updated the release post to add that Wink
Smile PrimeOS for Pinebook 1080p teamprimeos 1 16,916 10-05-2024, 11:22 PM
Last Post: brken
  Lineage + pinebook, havin an issue when porting it Phie 5 13,802 01-18-2021, 09:02 AM
Last Post: mindao
  [26/09/2019] /e/ on pinebook, lineage derivative Phie 16 44,201 03-29-2020, 06:22 AM
Last Post: Surehand53
  Privacy of Android and Chromium on new PineBook Clea 3 10,113 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 17,282 09-09-2019, 07:30 AM
  Stock Android for 1080P Pinebook pineadmin 1 8,056 11-24-2018, 09:45 AM
Last Post: ramboton
  Android 7.1 (Pinebook) pineadmin 50 112,063 05-30-2018, 03:13 PM
Last Post: Wizzard
  Android 6.0.1 (Pinebook) 20170605 pineadmin 6 18,458 12-30-2017, 06:55 AM
Last Post: milkaca
  Android 7.1 (Pinebook) v0.3.3-r59 pineadmin 3 11,470 05-09-2017, 04:59 AM
Last Post: Luke
  Pre-release android 7.1 for Pinebook Luke 0 7,174 04-22-2017, 10:58 AM
Last Post: Luke
