nexdock (laptop style HDMI display w/ BT keyboard/touchpad)
Came across the NexDock on IndieGoGo, a laptop styled miniHDMI 14" 1366x768 screen, with Bluetooth 4 Keyboard / Touchpad, 2x USB and a 38Wh battery.
It also comes with a TF card slot and 3.5mm audio jack; the exact usage of which I've not found yet.
It doesn't appear to have any USB B type ports, so I'm guessing the keyboard / touchpad is BT only and not available via USB.  I assume the audio jack is also BT.  Zero clue how to use the TF slot.
Personally for hobby stuff I was using a Hairer HLT71 which I got on clearance at Target for less than $50. It only has RCAs, and a pretty horrible 7" 416x234 resolution.  Since everything has been going HDMI I've beep keeping my eyes open for a cheap clearance/refurb portable HDMI tv/monitor.
I opted to back it at $99, thinking that a 14" HDMI display would at least cost that much, BT keyboard w/ touchpad, and 10,000mAh battery pack built-in being a bonus.
Thoughts?  Ever seen anything similar?  Anyone interested for their Pine64?
I'm hoping they hit their goals and actually ship.
http://nexdock.com/
https://www.indiegogo.com/projects/nexdo...-laptop--2
I am also interested in the Nexdock, but I want the USB Type-C port included.
They have a long way to go to reach that stretch goal.
NexDock Specifications
NexDock technical specifications:
  • Display – 14.1″ TN screen; 1366×768 resolution; 16:9 display ratio
  • Bluetooth 4.0 keyboard and touchpad
  • Video input – mini HDMI port
  • Audio Output – 3.5mm headphone port
  • Storage – micro SD card slot
  • USB – 2x USB ports
  • Battery – 3.8V / 10000mAh Li-ion battery
  • Power – 5V/2.5A via 3.5mm power barrel
  • Dimensions – 351 mm x 233 mm x 20 mm
  • Weight – 1490 grams
The NexDock dows have USB ports.
Here is a excerpt from the comments section for the Indiegogo crowd funding MexDock campaign.
quick question , from your resent update with pine 64 does it mean that i could buy nexdock and pine 64 and i would have a pc up and running that easily?
Answer  Yes, You can turn Pine64 into a full-blown computer with NexDock.
I like the concept and pledged .  But wished they had provided more technical details.  It looks like people were willing to buy the NexDock when the price was less than $100 but not when it is $119.  Hence it is unlikely NexDock will be funded.
hrh1818
The 2 USB ports provide the functions of a 2 port powered USB hub and access to a micro SD card.
hrh1818
Looks like they got an extension, the time left now is one month.
(03-06-2016, 10:46 AM)hrh1818 Wrote: The 2 USB ports provide the functions of a 2 port powered USB hub and access to a micro SD card.
hrh1818
In a recent update NexDock says one of the uHSB port's rating is 2 amps  and the other USB port's rating is 0,5 amps.
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 6,868 04-19-2019, 08:26 AM
Last Post: psychedup
  lcd touch screen and hdmi output moreaujacky 2 8,424 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 17,106 01-11-2018, 02:52 PM
Last Post: dkebler
  HDMI Compatability rahlquist 5 13,275 07-29-2017, 02:32 AM
Last Post: qwerty2002
  Ongoing HDMI limited compatability rahlquist 39 83,746 05-21-2017, 12:59 PM
Last Post: lbdroid
  No HDMI Output martinarcher 2 9,722 04-28-2017, 07:05 AM
Last Post: martinarcher
  Pine64 $15 card killed my $120 keyboard exa 22 46,932 01-04-2017, 09:01 AM
Last Post: skenn_ie
Rainbow Pine64 + waveshare display? iPhyse 4 11,796 10-12-2016, 04:43 PM
Last Post: hamzahbondok
  Switching from touchscreen to HDMI AUDIOTEK 10 21,095 08-11-2016, 07:41 PM
Last Post: MarkHaysHarris777
  4K HDMI video output medapeta 3 10,221 06-10-2016, 04:36 PM
Last Post: shinobi
