Serial Console: No input
Hello.
I am having issue with one distro so it was suggesting I use the serial console to access to see if the distro was booting correctly.
While I see the distro properly booting, but when I try to log in I am not getting any response when I try to type in.
I am using a Prolific PL2303TA based cable with the following pins
Black cable-----GND
Green cable-----TXD
White cable-----RXD
Red cable -------VCC
I have Green connected to pin 8, White connected to pin 7, and Black connected to pin 6
Any ideas on why there is no input?
Thanks!
(08-19-2017, 09:38 PM)KNERD Wrote: Hello.
Black cable-----GND
Green cable-----TXD
White cable-----RXD
Thanks!
If you're using the EXP header pins, and if you've connected to the right pins ( you've counted properly from the correct pin(1) )  then that should work.
When debugging a serial connection the first step is to run a loop-back...   with the echo turned OFF in your terminal software !   ... a simple wire jumper from pin(7) to pin(8).
With the loop-back jumper in place do you see the characters you're typing on your terminal software ?
If so,  then the problem is with your usb ttl bridge cable (pl2303 chip, or connectors).
If not,  then there is a problem with your config, uart setup, minicom terminal software (or other) , something like that.
So, let's start with the loop-back jumper and go from there.
Thanks for the awesome reply. I was able to finally get input to function.
(08-20-2017, 08:17 AM)KNERD Wrote: Thanks for the awesome reply. I was able to finally get input to function.
wonderful!    Smile
  Install OpenWrt on A64+ without serial? JuniperFury 5 11,465 12-25-2021, 10:31 AM
Last Post: guenther
  Cannot ship, need USB SERIAL CONSOLE/PROGRAMMER alternative please JuniperFury 5 11,584 10-29-2021, 07:13 AM
Last Post: TRS-80
  small console x0r 0 3,002 07-13-2019, 09:57 AM
Last Post: x0r
