Installer shows SD Card size 0GB
Question
For some reason the pine64 installer (on win7 32-bit) cannot recognise correctly the size of my sd card. It always shows 0.0 GB. The sd card (16GB micro sd hc class 1) works fine with all other devices and I formated it just before that.
(08-16-2017, 11:05 PM)atr.mbl Wrote: For some reason the pine64 installer (on win7 32-bit) cannot recognise correctly the size of my sd card. It always shows 0.0 GB. The sd card (16GB micro sd hc class 1) works fine with all other devices and I formated it just before that.
You can try :   h2testw    <===   for windows
... but you can also try  f3  { flash flash fraud }   <===  for linux
see this youTube link:
Smile
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 19,515 12-07-2020, 04:02 PM
Last Post: SanjevR
Lightbulb Boot from SD card / boot options lodger 13 38,446 11-26-2019, 07:14 AM
  Pinebook 1080p - Text Size bebop_man 2 6,620 10-02-2019, 06:19 AM
Last Post: bebop_man
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 3,498 05-19-2019, 04:46 PM
Last Post: Shoananas
  Installer does not work for me Tofu 4 10,097 12-02-2018, 12:55 AM
Last Post: Tofu
  [SOLVED] Can't boot when SD card inserted jschall 5 14,261 11-17-2018, 11:53 AM
Last Post: jschall
  How to mount new microSD card? jschall 8 15,755 11-12-2018, 11:04 AM
Last Post: jschall
  Move Installation from SD Card to eMMC? soupbowl 4 14,350 11-10-2018, 10:47 AM
Last Post: acruhl
  Do I really need PINE64-Installer? anaumov 13 23,977 08-14-2017, 04:47 PM
Last Post: shirman
  SD CARD - EMMC jmbernabotto 3 9,115 07-14-2017, 12:54 AM
Last Post: pfeerick
