Pine64 can run Ubuntu Server Arm, Ubuntu 15.10
#21
I am wondering if you will provide builds on the Pine64 page? Mainly because I know several backers that have no idea how to do the things needed to get the right OS or Kernel running on ANYTHING.
If you guys provided your testing packages and simple instructions I know that would make a lot of backers extremely excited.
Either way it will not be a huge deal once I have my board I will be testing OS versions and such that work with the kernel and will get anything and everything possible running. After If I have the time I will post on my page DL packages for all of those with specific information on which boards work best with it.
"Weakness of attitude becomes weakness of character."
-Albert Einstein
-Anderal (Michael Eddy Larson)
#22
(12-20-2015, 03:29 PM)ML-Anderal Wrote: I am wondering if you will provide builds on the Pine64 page? Mainly because I know several backers that have no idea how to do the things needed to get the right OS or Kernel running on ANYTHING.
We will provide build for Android first.
#23
Quote:
Quote:Getting GPU accelerations is generally going to be the hardest part as some BSPs need to be matched and/or compiled for specific X versions. I had many acceleration issues on the Udoo and its IMX6 since those BSPs were horrid to work with, whereas Pi2 has been fairly easy.
Thanks on the helpful tips.
The key is the BSP. I have several 'products' that never made it to maturity, they, the product creators, have given up and moved on. If the BSP is 'real' and by that I mean when you change a register the expected results happen than your product has a chance to reach maturity. I looked at what your providing and am curious about the CAMERA interface and the GPU encoding.
Either way with the power usage, Floating Point and cost this product will survive. How do I get a look at the BSP? You have my Email.
Kevin.
#24
The Linux BSP and Android image can be download from our wiki page at,
http://wiki.pine64.org/index.php/Main_Pa...e_Download
Regards,
KH Goh
  Programming languages support under PINE64 baryluk 6 20,691 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,665 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,186 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,671 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,130 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,220 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Issues with both Deb and Ubuntu germanshep 0 4,462 08-28-2018, 05:47 PM
Last Post: germanshep
  Official build procedure of ayufan pine64 r.tanaka 0 4,982 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,601 06-21-2018, 05:45 PM
Last Post: evilbunny
  need help, looking to setup NAS server over OpenWRT subbu 0 4,140 05-26-2018, 07:48 AM
Last Post: subbu
