Strange OpenSSL RSA speed Test issue
Hi guys,
i require your helps and ideas.
i run openssl speed rsa to evaluate the power of my PINE64+ board (i am a crypto guy).
i was a litle bit surprised to see big difference using different distribs :
 - the Debian Jessie with Mate DE [3.10.102 BSP 2] by Lenny Raposo    show me a nice 9.6 4096bits Private RSA / sec
while other dietPI and armbian get stuck to 6.4 4096bits Private RSA / sec.
So i decide to upgrade both the Debian Jessie Mate and dietPI to the latest kernel 3.10.105, run package update, then i force the CPU setting got from the debian to the dietPI :
sampling_down_factor = 1
sampling_rate = 2000000
sampling_rate_min=40000
up_threshold = 95
but got same result dietPI still show me  6.4 4096bits Private RSA / sec.
What do i miss ?
Any helps appreciate, thanks a lot
Check what scaling govenor is being used on the DietPi?
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
It has been set as interactive for a long time on the pine64 images... I think DietPi was a bit daft at one point and had it set at ondemand... maybe it still is? Also see what happens to your benchmark when you change it to performance.
sudo -i
echo performance> /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
exit
It was set to 'ondemand',
but your proposal to set it to 'performance' is what i might have done first,
and now i know that the cpu scaling is not the key :-(
all cpu clock set to 1152Mhz ...give same openssl rsa speed measure : 6.4 :-(   on the dietPi
  Ethernet issue Matthew 4 10,519 07-21-2017, 08:24 AM
Last Post: Matthew
  Variable Gigabit Ethernet speed? sheffield_nick 4 9,669 08-24-2016, 11:26 PM
Last Post: MarkHaysHarris777
  CPU speed / governor=performance? sheffield_nick 2 8,728 07-20-2016, 10:17 AM
Last Post: Fourdee
  network issue with no ethernet chrwei 4 11,481 05-03-2016, 11:22 AM
Last Post: longsleep
