Rock64 europe power supply voltage
Big Grin
Hi
I wonder why
SKU: R64-PB-POWER Categories: Pinebook, ROCK64
power supply input voltage are between  110V-220V AC
In europe the common voltage is 230V AC
Is it really only 220V AC ?
I trying to look at picture in store but the picture are not so clear.
Is there any approvals like UL,  TUV or SGS ?
CE is not real approvals :-)
BR: Kaarme42
The voltage difference is nothing to be concerned about, it's just that voltage standards are often not not well defined. For example, in the US the AC voltage may be called 110V, 115V, 120V or 125V. Same thing applies in Europe.
As for testing and approvals on the power supply, I do not know. The one I got with mine has TUV and GS/SGS.
(07-11-2017, 02:22 PM)fire219 Wrote: The voltage difference is nothing to be concerned about, it's just that voltage standards are often not not well defined. For example, in the US the AC voltage may be called 110V, 115V, 120V or 125V. Same thing applies in Europe.
Thank you for answering
Many years ago voltage  220V AC was quite common in europe.
Today voltage is 230VAC and ”all quality stuff" like  good phone charge are marked 100 -240.
If yours power supply are SKU: R64-PB-POWER and marked TUV and GS/SGS it is good news.
I think they do not give approvals to europe if max voltage is really only 220V (this is only my thinking not real fact)
BR: Kaarme42
  DeskPi case alternative for ROCK64 v1k699 2 13,540 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,770 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,663 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,728 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,613 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,135 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 22,139 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 10,504 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  rock64 totally brick dakobg 2 6,832 11-07-2022, 05:45 PM
Last Post: olivercfc
  Alternative power supply ju0n 0 4,040 09-06-2022, 02:46 AM
Last Post: ju0n
