USB3 performance tests
Thread to collect iozone performance tests of the rock64.
When posting a report, please list your board (1G/2G/4G), OS type and version (Xenial/0.2.5), hardware tested (make/model), and the file system it has (ext4/fat32/ntfs/etc). And don't forget to use code tags so the formatting doesn't stuff up Wink
If you don't have the iozone package installed yet: sudo apt install iozone3
Set the CPU governor to performance (as root, i.e. sudo -i first or pipe through sudo tee):
echo performance >/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Mount your drive, change to the mount point, and run the below to run your tests:
iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
( this page left blank intentionally )
One think to keep mind is that my board was one of pre-production samples, and I had to remove some of the ESD diodes as the wrong ones had been installed on the USB3 connector. Therefore my USB3 performance specs may not reflect the production model performance. And I certainly don't think this is the case, because my USB3 JumpDrive test subject didn't reach anywhere the below read speeds of my desktop in comparison:
Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 12722 11718 24340 24358 6719 462 102400 16 11709 22004 80089 3163 2931 2020 102400 512 4956 21783 1652 110923 99929 4928 102400 1024 6191 21576 116329 116532 111205 3978 102400 16384 6704 21469 117321 118603 117775 7132
rock64 /w 2GB, running Ubuntu Xenial ayufan 0.2.5, against an ext4 formatted cheap Lexar 16GB S75 USB3 flash drive. Write performance is nothing special, but I have had real world 100MB/s read speed from it on my desktop.
Iozone: Performance Test of File I/O        Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux  Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins             Al Slater, Scott Rhine, Mike Wisner, Ken Goss             Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,             Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,             Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,             Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,             Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,             Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Sat Jul  1 04:04:59 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size.                                                               random    random     bkwd    record    stride                                                   kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread           102400       4     7816     9891    12541    12347     4743      361        102400      16    17479    18596    31016    31207    14804     1840        102400     512    20835    20269    39598    39880    38142     5381        102400    1024    15217    20433    39748    40078    39282    10174        102400   16384    15714    19912    40093    40364    40329    21689                                                           iozone test complete.
Lets see what difference mount options make - ext4 with nodiratime and noatime mount options set:
Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins Al Slater, Scott Rhine, Mike Wisner, Ken Goss Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR, Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner, Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone, Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root, Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer, Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Sat Jul 1 04:45:18 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 7437 9725 11792 11556 4551 333 102400 16 17176 18255 29957 29993 14715 1819 102400 512 20811 20109 39708 39797 37948 6048 102400 1024 22432 14799 39986 40086 39193 7160 102400 16384 11263 19983 40172 40163 40166 21356 iozone test complete.
A comparision of the previous results against the lower USB2 port (ext4, same nodiratime, noatime mount settings):
Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins Al Slater, Scott Rhine, Mike Wisner, Ken Goss Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR, Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner, Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone, Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root, Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer, Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Sat Jul 1 05:00:07 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 7233 7695 9076 9093 4308 431 102400 16 11562 16447 21296 21271 12569 1722 102400 512 18149 19494 35323 35328 33954 5090 102400 1024 21691 19539 35900 35994 35326 10153 102400 16384 14447 18766 36429 36444 36409 21688 iozone test complete.
And to show how the filesystem has a big impact on the results, here is the same test again, but with the drive formated as vfat.
Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins Al Slater, Scott Rhine, Mike Wisner, Ken Goss Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR, Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner, Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone, Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root, Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer, Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Sat Jul 1 04:28:37 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 9991 11235 13096 13105 5529 447 102400 16 15100 17735 29883 29919 14464 1082 102400 512 10093 14090 39526 39633 37734 2981 102400 1024 17169 10783 39761 39907 38927 4239 102400 16384 16900 10989 40233 40312 40308 13258 iozone test complete.
And finally, a Seagate 4TB Expansion drive (mains power external hard drive) (actually got some high numbers this time).
Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux-AMD64 Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins Al Slater, Scott Rhine, Mike Wisner, Ken Goss Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR, Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner, Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone, Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root, Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer, Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Sat Jul 1 15:48:05 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 12722 11718 24340 24358 6719 462 102400 16 11709 22004 80089 3163 2931 2020 102400 512 4956 21783 1652 110923 99929 4928 102400 1024 6191 21576 116329 116532 111205 3978 102400 16384 6704 21469 117321 118603 117775 7132 iozone test complete.
Rock64 2G  ayufan minimal 0.2.1  over Sandisk Ultra 32G USB3.0  (partition sda1  FAT)
root@rock64:/media/disk2# uname -a
Linux rock64 4.4.70-ayufan-29 #1 SMP Sat Jun 24 09:54:27 UTC 2017 aarch64 aarch6
4 aarch64 GNU/Linux
root@rock64:/media/disk1# iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2        Iozone: Performance Test of File I/O                                                    Version $Revision: 3.429 $                                                      Compiled for 32 bit mode.                                                      Build: linux        Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins                       Al Slater, Scott Rhine, Mike Wisner, Ken Goss                                   Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,                         Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,                       Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,                     Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,                         Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,                         Vangel Bojaxhi, Ben England, Vikentsi Lapa.        Run began: Sat Jul  1 05:04:26 2017        Include fsync in write timing                                                  O_DIRECT feature enabled                                                        Auto Mode        File size set to 102400 kB                                                      Record Size 4 kB        Record Size 16 kB                                                              Record Size 512 kB                                                              Record Size 1024 kB                                                            Record Size 16384 kB                                                            Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2                                                              Output is in kBytes/sec                                                        Time Resolution = 0.000001 seconds.                                            Processor cache size set to 1024 kBytes.                                        Processor cache line size set to 32 bytes.                                      File stride size set to 17 * record size.        random    random     bkwd    record    stride        kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread                          102400       4     3381     3542    17698    17713     6892     2317        102400      16     9782    10693    51946    51985    25840     8346        102400     512    23797    28665   116286   116424    83992    27695        102400    1024    25392    30772   121727   121882    96416    29229        102400   16384    25742    30544   118115   118544   117167    29227        iozone test complete.
Rock64 2G  ayufan minimal 0.2.1  over Sandisk Ultra 32G USB3.0  (partition sda2  ext4)
4 aarch64 GNU/Linux
root@rock64:/media/disk2# iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2        Iozone: Performance Test of File I/O                                                    Version $Revision: 3.429 $                                                      Compiled for 32 bit mode.                                                      Build: linux        Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins                       Al Slater, Scott Rhine, Mike Wisner, Ken Goss                                   Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,                         Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,                       Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,                     Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,                         Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,                         Vangel Bojaxhi, Ben England, Vikentsi Lapa.        Run began: Sat Jul  1 05:08:20 2017        Include fsync in write timing                                                  O_DIRECT feature enabled                                                        Auto Mode        File size set to 102400 kB                                                      Record Size 4 kB        Record Size 16 kB                                                              Record Size 512 kB                                                              Record Size 1024 kB                                                            Record Size 16384 kB                                                            Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2                                                              Output is in kBytes/sec                                                        Time Resolution = 0.000001 seconds.                                            Processor cache size set to 1024 kBytes.                                        Processor cache line size set to 32 bytes.                                      File stride size set to 17 * record size.        random    random     bkwd    record    stride        kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread                          102400       4     3345     3458    17579    17643     6891     2220        102400      16    10251    10545    51004    51270    26487     7793        102400     512    27847    27979   114987   116405    84308    28311        102400    1024    29118    28763   119380   120638    97004    30187        102400   16384    30208    31251   119294   120471   119258    29213        iozone test complete.
Linux rock64 4.4.70-gd9f8397-dirty #4 SMP Thu Jun 29 21:45:40 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
Corsrair Flash Voyager GT3.0 128GB (ext4)
                                                     random    random                                     kB      reclen    write  rewrite    read    reread    read     write     409600       4     1640     1467    14241    15181     4174      571                                                           409600      16     5769     6545    43072    48283    19409     2867                                                           409600     512    24039    26066   135432   134970   112677    12135                                                           409600    1024    24033    27872   132993   133170   133392    13713                                                           409600   16384    27784    28047   135172   135434   137017    13825
For comparison on my Thinkpad W520 (i7@3.3Ghz) with linux-deepblack 4.11.5-200.fc25.x86_64
                                                 random   random KB      reclen    write  rewrite   read  reread    read   write 409600       4    1738    1689    22762    22883    4953     724                                                           409600      16    5841    6673    70025    70230   24736    2878                                                           409600     512   62620   76978   212627   211742  161889   24058                                                           409600    1024   33786   53683   202181   200167  175399   18183                                                           409600   16384   72790   70291   218358   218548  214972   23091
So considering that this kernel on Rock64 is pretty new this does not look bad at all...
Edit: The Thinkpad values have some weird bumps in them, maybe the file size is too small and testing some caching or buffer here instead of the physical device, going to rerun with large filesize...
Edit: re ran both tests with larger file size and the results are more consistent now...
Samsung 830 SSD (256GB) via JMS576 USB3/SATA bridge
                                                      random   random kB   reclen    write  rewrite    read    reread    read     write 102400       4    12489    13460    18838    19102    11612    13282                                                           102400      16    40500    50855    59763    61081    36515    50299                                                           102400     512   221087   247712   226089   236863   162081   237059                                                           102400    1024   246648   263610   265424   276265   216642   265984                                                           102400   16384   295448   290687   259715   344931   338378   290055  409600       4    11139    13589    20752    24122    11615    13388                                                           409600      16    49159    51439    61127    61224    36620    50698                                                           409600     512   230122   246652   238314   239178   161978   246797                                                           409600    1024   264338   276146   270927   276500   217073   277141                                                           409600   16384   304103   305119   326587   344885   339426   300827
                                                 random  random    KB  reclen   write rewrite    read    reread    read   write   102400       4   21423   24115    28178    27733   14561   25215                                                           102400      16   68165   74053    86389   102411   48260   73375                                                           102400     512  138509  146013   239740   251701  176170  154234                                                           102400    1024  169942  171816   248133   270721  213992  141895                                                           102400   16384  179981  173118   278754   298413  302857  169050 409600       4   21378   24261    28156    27951   14726   24664                                                           409600      16   66187   74002    97317   101167   48185   73957                                                           409600     512  145606  145452   253851   254371  168460  147119                                                           409600    1024  156023  154241   282162   282168  217111  156996                                                           409600   16384  172345  180110   299627   303149  297998  171165
Linux rock64 4.4.70-ayufan-44 #1 SMP Fri Jun 30 23:23:09 UTC 2017 aarch64 GNU/Linux
(ayufan rock64-linux-build 0.2.5, Debian Jessie minimal)
Rock64 2GB
JMS578 USB3-SATA bridge
iozone 3.429
Fujitsu MHZ2320BH G2 (320GB SATA II 2.5" HDD):
                                                             random    random              kB  reclen    write  rewrite    read    reread    read     write            102400       4     9585     9853    15916    16052      505     1257          102400      16    33132    40597    36156    36559     2003     4488          102400     512    59834    60235    59936    61614    31471    29695          102400    1024    59837    59851    60418    61825    41527    40858          102400   16384    59098    59610    59712    61113    59331    58107
Mushkin Reactor 1TB  (SATAIII SSD)
                                                             random    random                  kB  reclen    write  rewrite    read    reread    read     write              102400       4    23418    30958    53072    55828    54285    30586        102400      16    65510    80077   162489   199687   200624    79544        102400     512   132104   141360   360123   407862   393688   150870        102400    1024   135879   146159   358858   408018   409886   152794        102400   16384   139123   149558   387604   414441   406895   155065                                                               random    random               kB  reclen    write  rewrite    read    reread    read     write           409600       4    23897    32911    85195    85878    84021    30813           409600      16    74788    96754   233038   238268   233618    89421           409600     512   170051   178354   396565   394610   393492   192729           409600    1024   171501   198167   406016   407290   410254   200952           409600   16384   178575   191002   409648   410940   409529   201899
Linux rock64 4.4.70-rockchip-ayufan-54
                                                     random    random      kB  reclen    write  rewrite    read    reread    read     write 12288000       4    17768    22328    26129    25677    13302    21361                                                           12288000      16    61171    75520    79985    79982    43520    73117                                                           12288000     512   157411   241636   297964   297923   186737   107077                                                           12288000    1024   179415   259620   308459   320070   239986   166616                                                           12288000   16384   195302   232991   335103   352457   345601   153506
New test with 12GB file size (larger than total amount of RAM (4GB))
Got a new Samsung 850 Pro 512GB that has no TurboWrite cache limitations and shows consistent results:
Using performance governor, Linux rock64 4.4.70-rockchip-ayufan-63
                                                      random    random      kB  reclen    write  rewrite    read    reread    read     write  102400       4    20968    24845    26676    26698    19374    24635  102400      16    70207    80941    88054    88292    67557    80101  102400     512   321653   336076   321379   324059   310714   335604  102400    1024   339233   357436   344531   347485   335980   357374  102400   16384   380262   382923   372907   376392   376770   385885  512000       4    19888    23775    25765    25726    18844    23615  512000      16    66938    78642    86515    86357    66064    78171  512000     512   321743   337080   322441   322948   309481   336518  512000    1024   347813   359886   346130   346860   334981   358736  512000   16384   383644   390254   374593   376604   376778   390155 1024000       4    19744    23855    25601    25606    18783    23565 1024000      16    66630    78713    86207    86208    66007    78325 1024000     512   320690   336478   322200   322478   309082   335846 1024000    1024   348077   360385   346945   347055   335467   359869 1024000   16384   384325   390746   376154   376594   376869   390747 2048000       4    19879    23801    25728    25666    18828    23545 2048000      16    66985    78727    86657    86569    66110    78505 2048000     512   321543   336412   322320   322432   309687   335946 2048000    1024   348593   361011   347159   347206   335510   360497 2048000   16384   384588   391053   376554   376681   377071   390677 4096000       4    20812    24758    26674    26670    18845    23501 4096000      16    66792    79039    86881    86863    66209    78425 4096000     512   323192   338099   323223   323295   310381   337381 4096000    1024   349777   361814   347712   347885   336508   361470 4096000   16384   384818   391227   376734   376783   377083   391318 8192000       4    19936    23616    25665    25674    18820    23448 8192000      16    66554    78663    86662    86663    66216    78257 8192000     512   322356   336841   322462   322386   309928   335965 8192000    1024   349675   361284   347318   347322   335713   360914 8192000   16384   385254   391478   376539   376563   377012   391460 12288000       4    19713    23830    25809    25793    18855    23636 12288000      16    66437    78922    86639    86589    66172    78400 12288000     512   323947   338491   323495   323621   310947   337856 12288000    1024   350561   362392   348000   348130   336775   362454 12288000   16384   385473   391622   377176   377165   377518   391549
This is pretty close to the theoretical maximum of UAS over USB3 (ca. 400MB/s)
Rock 64 2GB with WD MyPassport 3TB USB 3.0
root@rock64:/public3# uname -a Linux rock64 4.4.70-rockchip-ayufan-83 #1 SMP Mon Jul 31 08:43:12 UTC 2017 aarch64 GNU/Linux root@rock64:/public# cat  /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor performance root@rock64:/public3# mount /dev/sdb1 /public3 root@rock64:/public3# iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2        Iozone: Performance Test of File I/O                Version $Revision: 3.429 $                Compiled for 64 bit mode.                Build: linux        Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins                     Al Slater, Scott Rhine, Mike Wisner, Ken Goss                     Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,                     Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,                     Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,                     Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,                     Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,                     Vangel Bojaxhi, Ben England, Vikentsi Lapa.        Run began: Fri Aug 18 14:49:23 2017        Include fsync in write timing        O_DIRECT feature enabled        Auto Mode        File size set to 102400 kB        Record Size 4 kB        Record Size 16 kB        Record Size 512 kB        Record Size 1024 kB        Record Size 16384 kB        Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2        Output is in kBytes/sec        Time Resolution = 0.000001 seconds.        Processor cache size set to 1024 kBytes.        Processor cache line size set to 32 bytes.        File stride size set to 17 * record size.                                                              random    random     bkwd    record    stride              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread          102400       4     7571    22266    23959    23821      677     1193          102400      16    50825    61413    67061    78620     3605     4979          102400     512    91674    66866    97883   112304    49333   128311          102400    1024    81612    61811    95844   128381    71115   153027          102400   16384    98765    83153   108218   128068   117287    94349 iozone test complete.
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 5,916 08-15-2022, 06:58 PM
Last Post: TRS-80
  Forcing u-boot to detect USB3 storage jandastroy 8 20,086 04-02-2019, 10:06 PM
Last Post: t4_4t
Rainbow USB3 Detection Issues When Booting Without USB Device Attached Dargmuesli 0 3,478 01-14-2019, 11:26 AM
Last Post: Dargmuesli
  USB3 problems scalextrix 2 6,499 09-08-2018, 01:15 AM
Last Post: scalextrix
  Rock64 USB3 bugs NitroDeath 4 12,498 09-02-2018, 03:00 AM
Last Post: NitroDeath
  Arch Linux USB3 Issues? decontainerized 4 12,595 07-25-2018, 04:39 AM
Last Post: cooker
  Flaky USB3 on Bionic ayufan image hackish 7 14,573 06-15-2018, 08:32 AM
Last Post: fire219
Sad Rock64 4GB poor USB3 HDD performance KernelPanic 7 21,271 04-11-2018, 02:20 AM
Last Post: KernelPanic
  Rock64 as a firewall - usb3 gigE adopters jl_678 2 7,591 02-19-2018, 03:16 PM
Last Post: spawnflagger
  Root FS on usb3 drive eloranta 7 13,114 12-18-2017, 10:43 PM
Last Post: eloranta
