Wifi applet after resume from suspend
You need a broader test base. If it works for two and not one, that's a terrible sample size. Are people in the IRC room experiencing this error on unsuspend?
Sorry all - I am mistaken.
The problem I am having is with the nm-applet icon being stuck as the two arrows (ethernet connetion?) after resuming from suspend. The wifi connection continues to work fine, however I can't see the list of AP's etc.
Killing and starting another nm-applet process fixes the issue.
Sorry for the confusion. Smile
M.
thanks for posting;
... the wifi (nm) gets grumpy when suspended;  if you think about it, it doesn't even make sense!
I would stop the wifi (nm) connection, then suspend;  after wake, resume the connection;
(06-30-2017, 11:34 PM)MarkHaysHarris777 Wrote: thanks for posting;
I have this issue as well but see spinny globes (i have changed to the mate dark theme so it may have different icons) as opposed to the ethernet double arrows. No wifi networks are visible and re-enabling/restarting wifi through the applet doesn't have any effect. This is happening for me on my as up to date pinebook without being the knife of the bleeding edge.
While the above user trick/process might work well, expecting users to change their behaviour will just annoy them. People coming from OSX and things "just working" (except when they really don't), (and likely some other mainstream systems,) are likely to get grumpy about having to manually do things a computer should "just get right".
have enabled the restart script - too soon to tell how well it works.
  Wifi doesn't work correctly Fredric92 1 8,474 08-10-2021, 08:39 AM
Last Post: Jean-Marc LACROIX
  Hibernation (suspend to disk) progress NoraCodes 4 14,437 08-28-2020, 03:46 AM
Last Post: ratel
  Flakey WIFI (problems authenticating, etc.) robbiemacg 6 14,940 12-15-2019, 04:31 AM
Last Post: matze79
  Wifi I/F on Pinebook 11.6" eblot 2 7,137 05-19-2019, 04:53 PM
Last Post: Shoananas
  Pinebook will not wake from suspend MECZero 6 13,981 12-02-2018, 12:17 PM
Last Post: oloturia
  WiFi on Xenial Minimal soupbowl 3 8,499 08-12-2018, 07:54 AM
Last Post: jblakeharris
Information How to manage Wifi in xenial-i3 i3wm image UPDATE MarkHaysHarris777 4 10,952 09-14-2017, 12:12 AM
Last Post: dahni
  Xenial Mate 0.7.5-88 - LCD off after resume nicole.f 4 9,932 07-22-2017, 07:48 PM
Last Post: pfeerick
