Install Influxdb & Grafana easy
Maybe to share for others that want to have this installed and find that it is hard to find the right sources for the pine64
influxdb installation
The standard download page does not show the right pine packages
use the following
curl -sL https://repos.influxdata.com/influxdb.key | sudo apt-key add -
sudo source /etc/lsb-release
echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee -a /etc/apt/sources.list.d/influxdb.list
After that simply install with
sudo apt-get update
sudo apt-get install influxdb
Grafana Installation
mainly coming from https://github.com/fg2it/grafana-on-raspberry/wiki
To get it working on the pine use the rpi2/rpi3 package.
You can install it by hand accoring to the instructions in the wiki.
If you want to keep it up2date you best use the apt installation.
sudo apt-get install apt-transport-https curl
curl https://bintray.com/user/downloadSubjectPublicKey?username=bintray | sudo apt-key add -
echo "deb [arch=armhf] https://dl.bintray.com/fg2it/deb jessie main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
the key difference here with the standard instructions is:
Once done you can simply install
sudo apt-get update
sudo apt-get install grafana
Hope this helps you
Hi, thanks for writing this down!
  Install OpenWrt on A64+ without serial? JuniperFury 5 13,792 12-25-2021, 10:31 AM
Last Post: guenther
  Is possible to install Home Assistant on pine64 2gb? polv89 1 9,867 04-02-2018, 05:22 PM
  kodi install on A64, 2GB gychang49 1 6,982 10-02-2016, 07:32 AM
Last Post: MarkHaysHarris777
  Install PlayBox Enclosure - pics sarts0703 1 5,057 09-05-2016, 04:29 PM
Last Post: jodybrown99
  Which OS will you install into your Pine 64? 7777777 21 40,404 04-26-2016, 12:19 PM
Last Post: Leoncito81
