What will you be using your PINE64 for?
#51
I am considering using mine as a living room PC as well. My questions - please help answer:
1. considering it has only USB2 ports, how can I connect to external storage for full speed streaming?
2. For streaming itself, should I go with Android & Kodi, or Linux & Plex Server?
I am anyways planning to cut open my WD Live Duo as its DLNA and server are pretty useless anymore.
I'm an OpenHAB  user now on RPI 2 using an aeon z-wave vs stick. Looking to move openHAB to PINE64SS and use the z-wave module for a more compact and powerful system. I will then add mosquito and hopefully a sensor or two off the gpios
#53
I will use Pine64 for drone and other automation projects.
#54
(02-28-2016, 06:41 AM)B34N Wrote: I'm an OpenHAB  user now on RPI 2 using an aeon z-wave vs stick. Looking to move openHAB to PINE64SS and use the z-wave module for a more compact and powerful system. I will then add mosquito and hopefully a sensor or two off the gpios
I will meet up with Kai Kreuzer this weekend and explore on better supporting for openHAB community.
... TL Lim
#55
I'll check it with ioBroker (homeautomation, IoT) and Xeoma (Video-surveillance).
Greetings,
Eric
#56
(02-27-2016, 09:45 PM)balaji_pitchumani Wrote: Hi,
Full speed streaming? You mean like watching videos? Pretty sure you'll be able to watch them off an external hdd. Use one port for a controller and the other for storage.
Backer number: 24,762
Backerkit STATUS: Items Received
#57
(01-30-2016, 07:26 AM)By-Jokese Wrote: VPN server, file system sync service (btsync), cloud print server (cups) and probably a small storage server with samba.
AFAICT, btsync will not operate on the pine64 because btsync is not designed for aarch64 Sad
#58
You should still be able to run and compile for aarch32 on aarch64 Linux as long as you include the 32bit libraries.  32bit libraries go in like /usr/lib and 64bit libraries go in /usr/lib64
#59
So, Bittorrent Sync (btsync) is closed source.  Are you suggesting that one could still run the aarch32 file on the aarch64 system?  This would be great news.  How does one go about installing the 32 bit libraries?
I tried using multilib (on arch) but it fails saying "error: failed retrieving file 'multilib.db' from mirror.archlinuxarm.org : The requested URL returned error: 404" https://wiki.archlinux.org/index.php/Multilib
A bit more reading into this and it looks like it might be possible to use chroot to create a 32 bit system inside our 64 bit system.  I haven't tried this yet, since it's a bit more involved.
#60
I'm going to try to use it to make a VR head-mounted display.
Question External storage problem for pine64 Dani6102 3 7,757 07-26-2023, 10:57 AM
  Pine64 as wireless audio device S265 3 9,953 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 4,920 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 46,618 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 5,971 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 5,902 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 8,179 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 6,252 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 9,461 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 13,504 05-03-2019, 02:48 PM
Last Post: Mendota
