MIPI 10.1 inch lcd setting up
Hi!
I am trying to connect B101UAN01.7 display(1920 x 1200) without any success.
Is pine64's driver supports other display than native 7"? If so, then could you please help me to understand where can be error?
Here is cutout from my device tree for 10.1" display
                 lcd0@01c0c000 {
                        compatible = "allwinner,sunxi-lcd0";
                        pinctrl-names = "active", "sleep";
                        status = "okay";
                        device_type = "lcd0";
                        lcd_used = <0x0>;
                        lcd_driver_name = "mb709_mipi";
                        lcd_backlight = <0x32>;
                        lcd_if = <0x4>;
                        lcd_x = <0x780>;
                        lcd_y = <0x4B0>;
                        lcd_width = <0x0>;
                        lcd_height = <0x0>;
                        lcd_dclk_freq = <0x94>;
                        lcd_pwm_used = <0x1>;
                        lcd_pwm_ch = <0x10>;
                        lcd_pwm_freq = <0xc350>;
                        lcd_pwm_pol = <0x1>;
                        lcd_pwm_max_limit = <0xfa>;
                        lcd_hbp = <0x78>;
                        lcd_ht = <0x7F8>;
                        lcd_hspw = <0x1>;
                        lcd_vbp = <0xC>;
                        lcd_vt = <0x4BC>;
                        lcd_vspw = <0x1>;
                        lcd_dsi_if = <0x2>;
                        lcd_dsi_lane = <0x4>;
                        lcd_dsi_format = <0x0>;
                        lcd_dsi_eotp = <0x0>;
                        lcd_dsi_vc = <0x0>;
                        lcd_dsi_te = <0x0>;
                        lcd_frm = <0x0>;
                        lcd_gamma_en = <0x0>;
                        lcd_bright_curve_en = <0x0>;
                        lcd_cmap_en = <0x0>;
                        lcd_bl_en = <0x30 0x7 0xa 0x1 0x0 0xffffffff 0x1>;
                        lcd_bl_en_power = "none";
                        lcd_power = "vcc-mipi";
                        lcd_fix_power = "vcc-dsi-33";
                        lcd_gpio_0 = <0x30 0x3 0x18 0x1 0x0 0xffffffff 0x1>;
(05-31-2017, 11:46 AM)vicb Wrote: Hi!
                 lcd0@01c0c000 {
                        status = "okay";
                        lcd_used = <0x0>;
                        lcd_if = <0x4>;
                        lcd_x = <0x780>;
                        lcd_y = <0x4B0>;
                        lcd_width = <0x0>;
                        lcd_height = <0x0>;
                        lcd_hbp = <0x78>;
                        lcd_ht = <0x7F8>;
                        lcd_hspw = <0x1>;
                        lcd_vbp = <0xC>;
                        lcd_vt = <0x4BC>;
                        lcd_vspw = <0x1>;
                        lcd_dsi_if = <0x2>;
                        lcd_dsi_vc = <0x0>;
                        lcd_dsi_te = <0x0>;
                        lcd_frm = <0x0>;
Hi!did you find the solution? I think that my screen is corretly connected and i think that this is my next trouble..can you help me with some advice?
Thank you!!!@@4@=@=+@=++`+
Hi
Is there any progress?
I am interested in this as well. Any update on connecting a 1920x1200 MIPI LCD to the Pine64-LTS?
Question +PINEBOOK How to go about setting up your own Jenkins build system for pine64 / pinebook images pfeerick 2 23,313 05-31-2017, 02:42 AM
Last Post: pfeerick
  Problems setting up webserver Ernst 6 13,561 08-01-2016, 10:33 AM
Last Post: jl_678
