Android 7.1 (Pinebook)
Android 7.1 (Pinebook) v0.3.5-r61 (SDCard). Note that, this build is for SD Card boot.
Thanks to Ayufan for building this image. Please visit the GitHub for more details about this image.
Edit:
Special thanks to Icenowy, lennyraposo, longsleep, lukasz, tkaiser, Xalius and PINE64 community contributors.
MD5 (GZip file): d052aa92041e20858dd2a0947be4dd15
(05-15-2017, 05:02 AM)pineadmin Wrote: Android 7.1 (PINEBOOK) v0.3.5-r61 (SDCard). Note that, this build is for SD Card boot.
I'm  having the same problem with this as I had with the r59 image.
It boots to the Android 4 dots animation and then just sits there showing it's cute animation. After a few minutes, I get a "Process system isn't responding" message.
Change did card to faster one with more iops, possibly Samsung evo.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(05-15-2017, 01:16 PM)ayufan Wrote: Change did card to faster one with more iops, possibly Samsung evo.
I am using a Samsung evo XC1 card. I'm using the Pine64 Installer on OSX to write the image.
Same issue here. Pine64 Installer on OSX
Just quick tested with environment below and it is working fine.
PINE64 Installer: 2.0.0-beta.2
macOS: 10.12.4
Pinebook: 11.6"
MicroSD: 16GB SAMSUNG EVO XC1
Note that, you need to wait around 5 minutes on first boot to allow it to initialized. My 2nd boot onwards took around 1 minute.
Mine was working fine until a few reboots later. Now it's just stuck at the boot animation and goes no further.
Is there any rescue mode or boot options to try and recover the installation or do I just have to start from scratch?
Thanks,
Martin
(06-23-2017, 02:57 AM)sickofthesea Wrote: Mine was working fine until a few reboots later. Now it's just stuck at the boot animation and goes no further.
Thanks,
Martin
I experienced a similar issue.  Worked great for the initial boot (although it took a bit longer than 5 minutes) but I am stuck on the boot animation after restarting.  Looked great for the few minutes I was able to use it.  I will try reflashing my Samsung EVO SD card and give it another shot.
Big Grin
Hi all,
Works just perfect to boot a newly flashed image... but after updating installed apps in google play I just get the 4 dots animated - forever (i.e. > 5 min)
But never the less - thanks for all efforts - looking good when it runs  Smile
Thanx
//Fred
(06-25-2017, 12:59 PM)epigon Wrote: Hi all,
Thanx
//Fred
Don't update sudo su binary - will break the installation. You need to reflash as there is not going back I am afraid :/
Smile PrimeOS for Pinebook 1080p teamprimeos 1 16,916 10-05-2024, 11:22 PM
Last Post: brken
  Lineage + pinebook, havin an issue when porting it Phie 5 13,802 01-18-2021, 09:02 AM
Last Post: mindao
  [26/09/2019] /e/ on pinebook, lineage derivative Phie 16 44,201 03-29-2020, 06:22 AM
Last Post: Surehand53
  SD2emmc custom android build Phie 0 4,438 11-06-2019, 09:14 AM
Last Post: Phie
  Privacy of Android and Chromium on new PineBook Clea 3 10,113 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 17,282 09-09-2019, 07:30 AM
  Bliss OS for Pinebook tllim 61 134,182 07-08-2019, 06:34 PM
  Android Oreo? epigon 12 30,477 07-02-2019, 03:18 PM
Last Post: TecapanV
Question 1080P Android 7? toca180 3 10,069 06-27-2019, 07:08 AM
  Stock Android for 1080P Pinebook pineadmin 1 8,056 11-24-2018, 09:45 AM
Last Post: ramboton
